January 7, 2012, 20:57 |
I created a tecplot binary file...
Lupo Ci
Rep Power: 16 |
Dear all, I wrote a fortran code to create a binary .plt file containing a triangular mesh and relevant results for each nodes that can be read from tecplot. I read the manual http://download.tecplot.com/360/dataformat.pdf here and I followed the instruction in appendix A (pag 147). I really cannot understand what s wrong with my code. Tecplot reads the file but the mesh is wrong. I checked everything plenty of times, everything looks fine to me. Did anybody do that?any tecplot expert that can tell me what is wrong with my code? I paste the code below. In my code nodi contains the number of nodes and maglie contains the number of cells. i am simply trying to obtain the triangular mesh made of 4 elements in figure 4.10 pag 130.
thanks Code:
Program tecplot IMPLICIT NONE INTEGER nodi,maglie,ncan,j,iter,i, buttaINT,iWRITE,nTIMEstep, & iREAD,MAXexten,posiz,nOUT,k,N1,N2,N3,kkk,M,nodiGEO,jSTAMPA, & NumVar,FileType,ZoneType,StrandID,VarLoc, & jmax REAL*4 dt,BUTTA,butta1,butta2,butta4,butta3,butta5 real*8 t,DBLEmin,DBLEmax integer, ALLOCATABLE :: iterOUT(:),n123(:,:),nodeCELLcenter(:) real*4, ALLOCATABLE :: vettore(:),tOUT(:),x(:),CSprint(:,:), & y(:),z(:),CSnod(:),CS(:,:),area(:),areaNOD(:) character*40 nomefile,FM,variab,NOMEFILEGEO,intNAME,fileBUTTA character*8 header character*1 aster CHARACTER*1 NULCHAR logical stampa nodi = 6 maglie = 4 x(1)=-1.0; y(1)= 0.0 x(2)= 0.0; y(2)= 0.0 x(3)= 1.0; y(3)= 0.0 x(4)=-0.5; y(4)= 0.8 x(5)= 0.5; y(5)= 0.8 x(6)= 0.0; y(6)= 1.6 numvar = 2 allocate (CSprint(max(maglie,nodi),numvar),nodeCELLcenter(numvar)) ! ! write BINARY FILE FOR TECPLOT ! ! All character strings are null terminated (i.e. terminated by a zero value) !header = '#!TDV112' iwrite = iwrite+1 write(36,rec=iwrite) '#!TDV112' !header iwrite = iwrite+2 !2 because it is a char*8 and it fills 8 byte (2*recl) !ii. Integer value of 1. buttaINT =1 write(36,rec=iwrite) buttaINT ; iwrite = iwrite+1 !iii. Title and variable names. FileType = 0 !Title and variable names. 0 = FULL,1 = GRID, 2 = SOLUTION write(36,rec=iwrite) FileType ; iwrite = iwrite+1 write(36,rec=iwrite) ICHAR('T') ; iwrite = iwrite+1 write(36,rec=iwrite) ICHAR(NULCHAR) ; iwrite = iwrite+1 ! write(36,rec=iwrite) NumVar ; iwrite = iwrite+1 !DO I=1,NUMVAR !!Variable names (INT32*N). N = L[1] + L[2] + .... L[NumVar]where:L[i] = length of the ith variable name + 1(for the terminating 0 value). write(36,rec=iwrite) ICHAR('x') iwrite = iwrite+1 write(36,rec=iwrite) ICHAR(NULCHAR) iwrite = iwrite+1 write(36,rec=iwrite) ICHAR('y') iwrite = iwrite+1 write(36,rec=iwrite) ICHAR(NULCHAR) iwrite = iwrite+1 !ENDDO !iv. Zones BUTTA = 299.0 !Zone marker. write(36,rec=iwrite) BUTTA ;iwrite = iwrite+1 write(36,rec=iwrite) ICHAR('Z') ;iwrite = iwrite+1 !Zone name (INT32*N). N = (length of zone name) + 1(for the terminating 0 value). write(36,rec=iwrite) ICHAR('O') ;iwrite = iwrite+1 write(36,rec=iwrite) ICHAR('N') ;iwrite = iwrite+1 write(36,rec=iwrite) ICHAR('E') ;iwrite = iwrite+1 write(36,rec=iwrite) ICHAR('1') ;iwrite = iwrite+1 write(36,rec=iwrite) ICHAR(NULCHAR) ; iwrite = iwrite+1 write(36,rec=iwrite) -1 !0 !ParentZone: 0 = indicates that this zone is not associated with a parent zone.>0 = A value greater than zero is considered this zone's parent. iwrite = iwrite+1 StrandID = 0 write(36,rec=iwrite) StrandID !IN REALTA IL MANUALE DICE StrandID=0 =>static zone StrandID: -2 = pending strand ID for assignmentby Tecplot; -1 = static strand ID; 0 <= N < 32700 valid strand ID iwrite = iwrite+1 t =t + DBLE(dt) write(36,rec=iwrite) t iwrite = iwrite+1 iwrite = iwrite+1 write(36,rec=iwrite) -1 !Not used. iwrite = iwrite+1 ZoneType =2 write(36,rec=iwrite) ZoneType !ZoneType 0=ORDERED, 1=FELINESEG, 2=FETRIANGLE, 3=FEQUADRILATERAL, 4=FETETRAHEDRON, 5=FEBRICK, 6=FEPOLYGON, 7=FEPOLYHEDRON iwrite = iwrite+1 VarLoc = 1 write(36,rec=iwrite) VarLoc !Specify Var Location. 0 = Don’t specify, all data is locatedat the nodes. 1 = Specify iwrite = iwrite+1 if (VarLoc.eq.1) then nodeCELLcenter(1) = 0 nodeCELLcenter(2) = 0 do i=1,numvar write(36,rec=iwrite) nodeCELLcenter(i) !0 = Node, 1 = Cell Centered (See note 5.) iwrite = iwrite+1 enddo endif write(36,rec=iwrite) 0 !Are raw local 1-to-1 face neighbors supplied? (0=FALSE 1=TRUE). iwrite = iwrite+1 write(36,rec=iwrite) 0 !Number of miscellaneous user-defined face neighbor connections (value >= 0). This value is in addition to the face neighbors iwrite = iwrite+1 write(36,rec=iwrite) nodi iwrite = iwrite+1 write(36,rec=iwrite) maglie iwrite = iwrite+1 write(36,rec=iwrite) 0,0,0 !ICellDim,JCellDim, KCellDim (for future use; set to zero) iwrite = iwrite+3 write(36,rec=iwrite) 0 !1=Auxiliary name/value pair to follow ; 0=No more Auxiliary name/value pairs. iwrite = iwrite+1 !v. Geometries !write(36,rec=iwrite) 399.0e0 ! Geometry marker. Value = 399.0 !iwrite = iwrite+1 !vi. Text !write(36,rec=iwrite) 499.0e0 !Text marker. Value=499.0 !iwrite = iwrite+1 !vii.CustomLabel !write(36,rec=iwrite) 599.0e0 !CustomLabel Marker; F=599 !iwrite = iwrite+1 !viii.UserRec !write(36,rec=iwrite) 699.0e0 !UserRec Marker; F=699 !iwrite = iwrite+1 !ix. Dataset Auxiliary data. !write(36,rec=iwrite) 799.0e0 !DataSetAux Marker; F=799.0 !iwrite = iwrite+1 !x. Variable Auxiliary data. !write(36,rec=iwrite) 999.0e0 !VarAux Marker; F=899.0 !iwrite = iwrite+1 write(36,rec=iwrite) 357.0e0 !EOHMARKER, value=357.0 iwrite = iwrite+1 !II. DATA SECTION write(36,rec=iwrite) 299.0e0 !Zone marker Value = 299.0 iwrite = iwrite+1 !i. For both ordered and fe zones: DO I=1,NUMVAR write(36,rec=iwrite) 1 !Variable data format (INT32*N), N=Total number of vars 1=Float, 2=Double, 3=LongInt,4=ShortInt, 5=Byte, 6=Bit iwrite = iwrite+1 ENDDO write(36,rec=iwrite) 0 !Has passive variables: 0 = no, 1 = yes. iwrite = iwrite+1 write(36,rec=iwrite) 0 !Has variable sharing 0 = no, 1 = yes. iwrite = iwrite+1 write(36,rec=iwrite) -1 !Zero based zone number to share connectivity list with (-1 = no sharing). FEPOLYGON and FEPOLYHEDRON zones use this zone number to share face map data. iwrite = iwrite+1 !Compressed list of min/max pairs for each non-shared and non-passive variables CSprint(1:nodi,1) = x(1:nodi); CSprint(1:nodi,2) = y(1:nodi); DO I=1,numvar if (nodeCELLcenter(i).eq.0) then jmax = nodi elseif (nodeCELLcenter(i).eq.1) then jmax = maglie endif DBLEmin = DBLE(MINVAL(CSprint(1:jmax,i))) DBLEmax = DBLE(MAXVAL(CSprint(1:jmax,i))) write(36,rec=iwrite) DBLEmin iwrite = iwrite+2 write(36,rec=iwrite) DBLEmax iwrite = iwrite+2 DO J=1,jmax write(36,rec=iwrite) CSprint(j,I) iwrite = iwrite+1 enddo enddo !ii. specific to ordered zones !iii. specific to fe zones do i=1,maglie ! do k=1,3 ! buttaINT = n123(k,i) ! write(36,rec=iwrite) buttaINT ! iwrite = iwrite+1 ! enddo write(36,rec=iwrite) 1, 2, 4 iwrite = iwrite+3 write(36,rec=iwrite) 2, 5, 4 iwrite = iwrite+3 write(36,rec=iwrite) 3, 5, 2 iwrite = iwrite+3 write(36,rec=iwrite) 5, 6, 4 iwrite = iwrite+3 enddo enddo STOP END |
June 8, 2012, 18:47 |
Missing DataPacking parameter
wen long
Rep Power: 14 |
The document is INACCURATE although it is a 2012 version. On page 150 of the pdf file, between
+-----------+ | INT32 | ZoneType 0=ORDERED, 1=FELINESEG, +-----------+ 2=FETRIANGLE, 3=FEQUADRILATERAL, 4=FETETRAHEDRON, 5=FEBRICK, 6=FEPOLYGON, 7=FEPOLYHEDRON and +-----------+ | INT32 | Specify Var Location. +-----------+ 0 = Don’t specify, all data is located at the nodes. 1 = Specif The following is missing: +-----------+ | INT32 | DataPacking 0=Block, 1=Point +-----------+ See an earlier version of the document (line 83): http://download.tecplot.com/tecio/360/binaryformat.txt Hopefully this solves your problem. Wen |
June 12, 2012, 15:14 |
Andreas P
Rep Power: 16 |
seems that you are not using the tecio library for writing the .plt file.
any specific reason for that? for me the library has always worked fine. so this might help you... best, andreas |
June 12, 2012, 15:49 |
wen long
Rep Power: 14 |
I'm trying to get it going with matlab/octave. The tecio works fine, but I find it not convenient to call the c programs from matlab.
If you have done that, please let me know. |
June 12, 2012, 16:07 |
Andreas P
Rep Power: 16 |
Sorry I don't really have experience with C functions in matlab. The only thing I know is that you need to use this MEX interface. Possibly, you are also required to use a certain compiler for your C code in order to stay compatible with the Matlab runtime libs. (For gcc I somehow believe you must not use a compiler newer than gcc 4.4... just breaking out old memories with no guarantee...)
But anyway, it should be possible (with moderate effort) to call C/C++/Fortran routines from Matlab... |
June 12, 2012, 17:03 |
wen long
Rep Power: 14 |
Thanks! I'm 3 quarters done with writing a matlab function that will generate binary plt files (lines, surfaces, bricks, finite elements and geometries) without using tecio or mex. I will post it here for folks to use after I finish debugging.
The tecplot has now deprecated POINT type of datapacking. |
June 27, 2012, 20:56 |
mat2tecplot.m
wen long
Rep Power: 14 |
Dear all,
I finally finished and tested a matlab program that will dump data to tecplot binary format directly without using tecio. I'm loving it and here you go. Please see the attached mat2tecplot.m . Simply unzip it and type in matlab command: mat2tecplot It will show you how it works. Wen Long |
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 09:33 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
