Home > Forums > Visualization & Post-Processing Software > Tecplot
why can't I use tecplot to draw a streamline?
Like Tree2Likes
  • 2 Post By leflix
Old   May 10, 2009, 12:13
Default why can't I use tecplot to draw a streamline?
Edison
hadesmajesty is on a distinguished road
I can use tecplot to draw a vector graph, but when I try to draw the streamline, it shows that "not all the points along the rake were within the data field"? What's wrong?
Thank you.
hadesmajesty is offline   Reply With Quote
Old   May 11, 2009, 19:22
Default reply
CFDstudent is on a distinguished road
first of all, you CAN draw streamlines in Tecplot
-make sure you are in domain mode ( not in X-Y line)
-where are you importing your velocity data from? (what CFD package?)
-try a few point drops (as opposed to a rake) just to make sure that it is not the data. for example, it make not be able to resolve spurrious velocities
-try adjusting your streamline settings (box next to the streamline icon). try adjusting rake density, interpolation mechanism, etc.
i think if you just play around with it enough you should be able to get it to work....that is, like i said before, if it is just bad data that cannot be resolved. does your velocity field seem reasonable?
CFDstudent is offline   Reply With Quote
Old   May 6, 2012, 03:40
Default Regarding plotting streamlines
Adnan
adnanakhtar is on a distinguished road
Can someone please help me to plot streamlines?
I have got a data file with x,y,u and v.
I am able to plot the vector plot but am unable to plot the streamlines.
Can someone please tell the steps or procedure to plot the streamlines from this data file?
ITS URGENT
adnanakhtar is offline   Reply With Quote
Old   May 6, 2012, 19:35
leflix is on a distinguished road
ITS URGENT
It's very easy !You have two ways to do it. Once you have displayed the velocity field, clikc on the box "streamtrace" on the left side, juste below Zone style. Then click on the symbol which is like two arrows after the button "..." . Then on your figure, click from the bottom left corner up and draw a straight line up to the upper right corner of your figure. Then release the mouse. You may see appear a box which says "Not all points along the rake were within the data field" . It doesn't matter. click ok Then it will draw the streamlines.
Or you can just click anywhere on you figure where you want to add a streamline. Then you add as much streamline you need where you need some.. You should have first clicked on the symbol of the two arrows.
Shaqpad and elham usefi like this.
leflix is offline   Reply With Quote
Old   September 15, 2019, 21:45
Default Thanks
Sidique Gawusu
Sidique is on a distinguished road
Thanks. Works perfectly
Sidique is offline   Reply With Quote
Problem Exporting to Tecplot Craig FLUENT 2 July 16, 2008 00:21
Draw streamline in 3D Emad FLUENT 0 December 4, 2007 12:50
Using Tecplot for contours display david FLUENT 2 August 23, 2005 23:37
Draw velocity profiles in tecplot scubme FLUENT 1 December 3, 2004 09:48
Tecplot can't read data file from Fluent. stephen FLUENT 8 November 21, 2001 21:27
