Home > Forums > Visualization & Post-Processing Software > Tecplot
Extract field data in tecplot over time
Like Tree1Likes
  • 1 Post By wsfowler
Old   January 13, 2024, 08:17
Default Extract field data in tecplot over time
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Hello everyone,
I'm going to prepare some data for machine learning. To this end, I need to get field data such as pressure and velocity over time for all cell centers.
However, I have simulated my problem in Fluent Unsteady. So, how can I extract the field data in tecplot over time?
In tecplot I follow up these procedures:
  1. create macro
  2. load data
  3. create rectangular zone
  4. interpolate data to the zone
  5. and finally write the data
All are good, except third step, where I should define I and J numbers.
How can I extract data for all cells over time respectively?
Thank you.
saeed jamshidi is offline   Reply With Quote
Old   January 14, 2024, 07:09
Saeed Jamshidi
Any Idea?🙏
Old   May 6, 2024, 19:50
Scott Fowler
wsfowler is on a distinguished road
PyTecplot is a great way to grab raw data from Tecplot 360.
If the data are already cell-centered, simply grab and array of data using the following PyTecplot (python code)
import tecplot as tp
from tecplot.constant import *
dataset = tp.active_frame().dataset
# Get an array of Pressure values for the first zone
zone = dataset.zone(0) # zone numbers are zero based in PyTecplot
variable = dataset.variable("Pressure")
values = zone.values(variable)[:]
# Loop over all zones and all variables, getting the cell-centered data values
for z in dataset.zones():
    for v in dataset.variables():
        var_values = z.values(v)
        if var_values.location == ValueLocation.CellCentered:
            cc_values = var_values[:]
            # Do something with cc_values
saeed jamshidi likes this.
wsfowler is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 09:27
Convergence problem of OF WUYing OpenFOAM Running, Solving & CFD 2 September 20, 2021 11:09
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
