Home > Forums > Visualization & Post-Processing Software > Tecplot
How to show all time zone in tecplot?
Like Tree1Likes
  • 1 Post By wsfowler
Old   November 15, 2020, 21:33
Default How to show all time zone in tecplot?
Jim
haizhou0410 is on a distinguished road
Hi Guys,
I am doing unsteady simulations now. I exported several plt files (0001.plt...0010.plt...) for some timesteps. I loaded these files in the Tecplot, it only displayed the zones of the first file. Although I can make animations using Animatie-time..., how can I display all time zones together? When I opened the Zone style... it only shows the zones of the first file. But when I open the Data set info, it shows the zones of all the files. Thank you in advance!
haizhou0410 is offline   Reply With Quote
Old   November 23, 2020, 16:16
Scott Fowler
wsfowler is on a distinguished road
Tecplot 360 treats zones as transient that share the same "Strand" number and will only show the zones that are relevant at the determined time step. If you want to see all the zones simultaneously you have two options:
1) Change the solution time for each zone to be the same - you'll still only have one entry in the Zone Style dialog.
2) Give each zone a Strand of zero - A zero value will instruct Tecplot 360 to treat the zones as "static" (i.e. no longer transient) and they'll show up individually in the Zone Style dialog and display simultaneously.
I believe Option #2 will be best for your use case.
You can change the Strand number in the Data>Edit Time Strands... dialog.
QLiang likes this.
wsfowler is offline   Reply With Quote
Old   November 24, 2020, 05:06
Jim
Thank you very much wsfowler! The Option #2 worked!
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
