August 25, 2020, 09:05 |
Normalisation of x and Y axis
Arun
I have plotted the contour plot using Tecplot. X and Y are in the range of -300 to 300mm and 0 to 300 mm respectively. Now I would like to normalise these coordinate using 50mm, so can any one help me how to do this?
Thank you in advance.IMG-20200825-WA0003.jpg |
August 28, 2020, 17:01 |
#2 | |
Sibylle Walter
Rep Power: 6 |
You mean you want the Y range to go from -6 to 6 and X to go from 0 to 6? The easiest way is to make a new variable (Data --> Alter --> Specify Equations...): {Height} = {Y}*1000/50 {Width} = {X}*1000/50 (The "*1000" is to convert from meters to mm and the "/50" is to normalize to 50). You can then go to Plot --> Assign XY... and select Height for your Y axis and Width for your X axis. |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 19:05 |
[DesignModeler] axis display disparity of model and triad | ram881973 | ANSYS Meshing & Geometry | 14 | November 18, 2020 02:21 |
[blockMesh] Wierd behaviour of blockMesh creating axis in wedge | rcastilla | OpenFOAM Meshing & Mesh Conversion | 1 | December 4, 2018 07:24 |
[Other] dynamic Mesh with angular velocity not parallel to x axis | donQi | OpenFOAM Meshing & Mesh Conversion | 5 | October 3, 2014 00:19 |
Axis treatment in axisymmetrical problem | Jakob1 | OpenFOAM Pre-Processing | 2 | August 25, 2014 04:09 |
