Home > Forums > Visualization & Post-Processing Software > Tecplot
Strange spots on 2D surface
Like Tree2Likes
  • 1 Post By novedevon
Old   July 30, 2020, 06:22
Default Strange spots on 2D surface
Alessandro Donadeo
AlphaDelta is on a distinguished road
Hi everyone.
As you can see from the figure, by importing my 2D simulation from STAR CCM+ into Tecplot (.case format) you notice strange "spots" on the surface.
I can't understand what it is due to.
NB: I used a polyhedral mesh.
Thanks.
File Type: jpg WhatsApp Image 2020-07-29 at 14.00.07.jpg (40.6 KB, 9 views)
AlphaDelta is offline   Reply With Quote
Old   July 31, 2020, 13:11
novedevon is on a distinguished road
If this is truly a 2D simulation a non-grid variable is likely being assigned to your z axis. Either swap to 2D Cartesian plot type from the plot sidebar. or ensure that a variable which is constant is assigned to the Z axis by going into Plot> Assign XYZ if something other than Z is assigned you can create a z variable by going into data>Alter> specify equations and enter '{Z}=0' and then use that in Plot>Assign XYZ as your z variable.
AlphaDelta likes this.
novedevon is offline   Reply With Quote
Old   July 31, 2020, 13:42
Alessandro Donadeo
Thanks for reply!
Moving on to 2D Cartesian the problem disappears.
However in 3D Cartesian no. The variable associated with the Z axis was already inserted correctly; also creating a new variable, initializing it to zero and using it in the "Assign XYZ" dialog the spots remain.
I have attached the .zip file and also some images that make it clear how the spots I think are cells of the mesh.
I noticed that the problem is present only when the Shade toggle is activated.
The problem is present only Lighting effect is activated.
Thank you!
File Type: zip ZAU.zip (490 Bytes, 2 views)
Old   July 31, 2020, 14:23
Thanks for the more detailed screenshots, in them it looks like this is actually a known bug with Tecplot's shading layer.
The current recommended work around is to switch to paneled shading (it only effects Gouraud shading) for the zones which are effected. To do this go into Zone Style> Effects Tab> Lighting Effects> Paneled.
(Note, Ensight case files need the supporting files to load into Tecplot, if you could send the full set to support@tecplot.com that would be helpful when fixing the bug)
Devon
Tecplot Product Manager
Old   September 18, 2023, 04:06
Default 2D plot in tecplot of different faces a triangle
Muhammad Usman is on a distinguished road
I have data for face T1 to T2, T2 to T3, and T3 to T1. How can I do the plotting as an attached file?
Muhammad Usman is offline   Reply With Quote
postprocess, spot, star ccm+, surface, tecplot
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[snappyHexMesh] Surface triangulation using snappyHexMesh shaileshbg OpenFOAM Meshing & Mesh Conversion 4 October 17, 2019 05:42
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
VOF Modeling: two-phase flow in microchannel, getting strange flow spots M_H215 Fluent Multiphase 4 August 25, 2015 15:20
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
