Home > Forums > Visualization & Post-Processing Software > Tecplot
How to scale the axis in Tecplot like the fluent scale function
Like Tree1Likes
  • 1 Post By novedevon
Old   July 2, 2020, 17:24
Default How to scale the axis in Tecplot like the fluent scale function
hitzhwan is on a distinguished road
How to scale the axis in Tecplot like the fluent scale function? I do not need the data in decimal, can we change it into interger?
hitzhwan is offline   Reply With Quote
Old   July 2, 2020, 19:46
novedevon is on a distinguished road
Plot> Axis > Range(tab)> Dependency and set the setting to independent and you can use the x to y ratio to change the ratio displayed on the plot.
If you want to change the data itself rather than the plot use Data> alter> specify equations and alter the data.
CFDger likes this.
novedevon is offline   Reply With Quote
Old   July 3, 2020, 16:49
Default Thank you, the second one is the one I want, I have another two question: 1. How can
1. How can we set the title name of axis as italic?
2. Could we plot path line (not streamline) in Tecplot?
Old   July 6, 2020, 15:29
1) double click on the axis title and it will launch Axis details with the axis title tab and then click the italic button and tada your title should be italic
2) Analyze > Particle Paths and Streaklines should be what you are looking at. Have a look at the help button there to read how to use them.
Old   July 7, 2020, 18:21
Default Do you have any vedios to discribe it clearly, I find the help is not very good to le
Do you have any vedios to discribe it clearly, I find the help is not very good to let me understand.Thank you.
Old   July 8, 2020, 16:52
This is the closest we have at this point.
https://www.tecplot.com/2014/10/31/s...article-paths/
Feel free to contact support@tecplot.com if you have additional specific questions.
Old   July 8, 2020, 18:42
Default Thank you , I see it, but it is not what I want , can you give a vedio about the path
Thank you , I see it, but it is not what I want , can you give a vedio about the pathline in line, not the ball.
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
