Wrong calculation of force and moments in Tecplot |
March 24, 2018, 00:35 |
cyln
Rep Power: 10 |
I performed a CFD analysis over a bluff body. When I calculate the drag force on the body in Tecplot (Perform Integration --> Forces and Moments), I get a very high value. I can simple estimate the amount of drag force: - D = C_d 1/2 rho V^2 A rho=1.225 , A=0.0378 m^2 , V= 40 m/s D= 37C_d The value for the drag force I get from Tecplot is: Drag: -2.265107e+004 which is too much. Has anybody ever got such a problem from tecplot? Cheers, Cyln |
March 26, 2018, 19:31 |
Dave Taflin
Rep Power: 9 |
Ensure you've set viscosity in the Fluid Properties dialog to a value consistent with your data's units, and that you've identified solution variables correctly in the Field Variables dialog.
August 18, 2020, 02:42 |
Pavel Chuvakhov
Yeap, one should set the correct viscosity first
6DOF solver (buoyancy and hydrostatic force) | ZacHillAdl | Fluent UDF and Scheme Programming | 2 | March 27, 2017 16:20 |
[swak4Foam] viscous force calculation with MRF | zordiack | OpenFOAM Community Contributions | 4 | March 4, 2015 10:19 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 08:26 |
how does Fluent calculate the pressure and viscous force vector? | Ralf Schmidt | FLUENT | 2 | May 17, 2010 16:49 |
