July 29, 2017, 15:20 |
Grid I Unit Normal and Grid J Unit Normal
Rep Power: 9 |
What is the difference between “Grid I Unit Normal”, “Grid J Unit Normal” and “Grid K Unit Normal”?
In 'Tecplot-> Analyze -> Calculate Variable' there are three types of Unit Normals listed namely "Grid I Unit Normal", "Grid J Unit Normal" and "Grid K Unit Normal". I want to know the difference between them! Thanks and Regards |
July 31, 2017, 16:41 |
Scott Fowler
Rep Power: 17 |
These are unit normals that point normal to the I-, J- or K-plane, in the plus-index direction. Appendix section F-3.1 briefly discusses these, but makes no mention of meaning or behavior for FE zones.
Only Grid K Unit Normal is meaningful for finite element surface zones; the direction it points is determined by cell right-hand rule. Regards, Scott |
July 31, 2017, 17:37 |
#3 | |
Rep Power: 9 |
Scott: Thanks for your reply. It is really helpful and gave me some idea.
Although if you find anything regarding meaning of 'Grid I Unit Normal' and 'Grid J Unit Normal' please let me know. Thanks and Regards pawansut Quote:
July 31, 2017, 19:00 |
Scott Fowler
Rep Power: 17 |
Grid I Unit Normal and Grid J Unit Normal are only meaningful for structured grids. They represent the normal in the positive I- and J-
directions respectively. Grid K Unit Normal is meaningful for both structured and unstructured grids. For structured grids it is the normal in the positive K- direction. For unstructured grids it is the normal for surface cells (triangles & quads) in the direction determined by the right-hand rule. Hopefully that provides a more explicit definition for you. |
July 31, 2017, 19:14 |
#5 | |
Rep Power: 9 |
Scott: Yes! Indeed. Thanks a lot.
I needed this explanation. Thanks and Regards pawansut Quote:
[ICEM] Output normal directions of grid nodes | mars | ANSYS Meshing & Geometry | 0 | January 18, 2016 11:04 |
Wall normal grid configuration in pipe | hnemati | Main CFD Forum | 1 | January 7, 2014 09:52 |
grid normal to wall | lavdwall | Main CFD Forum | 3 | January 7, 2014 05:19 |
grid software for normal vector | cepheid | Main CFD Forum | 0 | May 21, 2010 23:22 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 12:18 |
