How can I compare two cases in Tecplot? |
yehanyu
Rep Power: 14 ![]() |
Hello everybody,
I have two FLUENT cases and their meshes and boundary conditions are identical. The difference is that the two cases are computed with different solver settings (time step size, spatial discretization scheme, etc.). Now I want to compare these two cases. Does anybody know whether I can subtract these two cases in Tecplot? (for instance, subtract the velocity field of case 2 from that of case 1, then I can examine the difference of velocity field between these two cases) |
Svetlana Tkachenko
- Export the data from Fluent to Tecplot.
- Load both data sets into Tecplot. - Data → Create Zone → Duplicate. Duplicate any zone you like, click OK. - Data → Alter → Specify equations. Select the third zone. Write {VARNAME}={VARNAME}[2]-{VARNAME}[1], replacing VARNAME with the variable name of interest. Click Compute. |
#3 | |
yehanyu
Svetlana Tkachenko
You're welcome.
dan
Rep Power: 9 ![]() |
In newer versions of Tecplot (360) you dont have to export first. You can just load in a cas/dat file. Then load in another cas/dat pair and click "append data" in the pop up
Svetlana Tkachenko
Thanks deenriqu, you are right and it makes the comparison a lot easier
comparison, subtraction |
FlowSight - Compare Cases | arhabib | FLOW-3D | 0 | December 22, 2016 13:28 |
Loading Cell Values in Tecplot | P1361 | OpenFOAM Post-Processing | 3 | September 16, 2014 04:02 |
Fortran unformatted to tecplot binary | sdharmar | Tecplot | 2 | April 9, 2014 07:19 |
Is OpenFOAM tutorial cases valid? | j-avdeev | OpenFOAM Running, Solving & CFD | 3 | September 19, 2012 15:45 |
How to speed up the simulation of a large amount of similar steady state cases | tss | Main CFD Forum | 4 | November 5, 2010 14:36 |
