Home > Forums > Visualization & Post-Processing Software > Tecplot
Plotting average value of a variable in XY plane.
Like Tree2Likes
  • 1 Post By scott_rumage
  • 1 Post By esha
Old   November 7, 2015, 01:56
Default Plotting average value of a variable in XY plane.
HK
Luttappy is on a distinguished road
Hi all
I am new to Fluent and Tecplot.
I am working in flow and heat transfer study in a plane channel.
Anyone help me how to plot mean temperature (Mean/average of temperatures along Y direction/constant x lines) and x in tecplot.
Thanks in advance
Luttappy is offline   Reply With Quote
Old   November 9, 2015, 12:05
Default Calculating and plotting extracted variables
Scott Rumage
scott_rumage is on a distinguished road
I believe the first step to creating the plot you need is to extract a line along the constant x value, and then plot that extracted line (which is a new "zone" in the Tecplot paradigm). To get a sense of this process I would recommend watching the Tecplot tutorial video titled:“External Flow – Comparing a CFD Simulation with Experimental Data” at this link: http://www.tecplot.com/blog/category/video/?product=360 as the creation of the Cp plot is similar in concept to what I think you want to accomplish.
Scott
P.S. It would be a good idea to watch all of the videos on the linked page if you are a new user of Tecplot 360 EX to get a sense of the Tecplot application paradigm.
Luttappy likes this.
scott_rumage is offline   Reply With Quote
Old   November 17, 2015, 02:03
HK
Thanks a lot for the information
In that video they are plotting variable along a slice. But in my case I want to find the average value of the variable (say Temperature) with x direction.
For example consider a plane channel, here we have 273 grid divisions are in X direction and 27 grid divisions are there in Y direction. I want to plot a average value of variable (say Temperature) with X axis. Here each point in the graph will be the average value of the variable at 27 nodes. Hence I need to find the average value of variable at 273 constant x planes and plot which is a difficult task if we do manually.
Thanks for any suggestions.
Old   December 29, 2019, 07:32
esha is on a distinguished road
hi,I have almost same problem. I am also trying to plot average value of cp around 3d object. I can plot Cp. but for average it is showing a straight line. But I want to plot mean at every point of bluff body. I have selected a slice. but can not get right result. how you have overcome this problem.nplease share with me. I will be thankful!
@ss likes this.
esha is offline   Reply With Quote
Old   December 30, 2019, 15:18
Scott Fowler
wsfowler is on a distinguished road
You can compute an average of a zone through time by using Analyze>Perform Integration. If you have unsteady simulation results, you can do this through time, to get a plot with Time on the X-axis and Average on the Y-Axis.
This video computes Mass Flow rate over time, but the concept is similar:
https://www.tecplot.com/2018/12/13/c...ass-flow-rate/
wsfowler is offline   Reply With Quote
Old   June 12, 2021, 08:20
Ekha
ekha is on a distinguished road
Did you find a way to plot the time averaged data along y direction with x over a 2D plane?
The integral option in tecplot plot the averaged data of the whole plane with time . But not as the description above.
Thanks
ekha is offline   Reply With Quote
Old   November 21, 2023, 03:51
@ss
shristi
@ss is on a distinguished road
hi
I am also trying to plot the contour of average value of cp around 3d cylinder with time in tecplot. can anyone tell me how to plot contour of average pressure on z direction of 3d cylinder with time.
Thank you
@ss is offline   Reply With Quote
Old   November 21, 2023, 13:33
Scott Fowler
Tecplot has some scripts that can be used for computing a time average.
Check out the video at this link: https://tecplot.com/2022/06/29/pytec...ta-statistics/
Hopefully this helps. If you need additional help, I'd suggest contacting our support staff.
Using a Plane id in Fluent UDF cdf_user Fluent UDF and Scheme Programming 13 October 17, 2023 01:06
Spatial average over a plane michel1988 OpenFOAM Programming & Development 17 November 30, 2014 03:41
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
calculation average pressure in a plane with UDF Vitalij FLUENT 1 April 10, 2007 04:39
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
