October 1, 2015, 08:23 |
Time Averaged Data (for flow field) TECPLOT
Hi there,
I am using Tec360 EX15. Trying to archieve a time-averaged variable I loaded data from different timesteps into Tecplot. Then I tried to specify an equation. Due to having a lot of zones I wrote a Macro: " #!MC 1400 $!VarSet |NUMAVG| = (|NUMZONES|-1) $!Loop |NUMAVG| $!AlterData Equation = "V21 = V6 + V6[|LOOP|]" $!EndLoop $!AlterData[|NUMZONES|] Equation = "V22 = V6/|NUMAVG|" But it gives me the error: "Incompatible zones referenced in equation...V21 = V6 +V6[1] " so does this mean it only reads in 1 zone?? Could somebody please help me :/ Best regards |
October 5, 2015, 18:17 |
RE: Time Averaged Data (for flow field) TECPLOT
Jared McGarry
Rep Power: 11 |
Hello BiancaB,
I believe the issue was with defining V21 as a function of V6 for all zones summed with V6 for a specific zone ( V6[|LOOP|] ). Also, if you want to find the sum, you must set the sum variable as the addition of the previous sum variable in the loop and the desired variable for that zone in the loop. You can also run in to this error if V21 or V22 have not already been defined. To avoid this, it is often safer to create new variables based on a specific name rather than on variable number. Below is a macro that will, based on your chosen variable (in this case V6), create two new variables for the sum {sum_V6} and average {avg_V6}: #!MC 1400 $!VarSet |NUMAVG| = (|NUMZONES|) $!ALTERDATA EQUATION = '{sum_V6} = 0' $!Loop |NUMAVG| $!AlterData EQUATION = '{sum_V6} = {sum_V6} + V6[|LOOP|]' $!EndLoop $!AlterData[|NUMZONES|] Equation = '{avg_V6} = {sum_V6}/|NUMZONES|' Let me know if this helps! Jared Technical Support Specialist Web: www.tecplot.com Last edited by JMcGarry; October 22, 2015 at 17:41. |
August 9, 2016, 09:18 |
Manu Chakkingal
Rep Power: 10 |
Hi
WHat if the time steps are not equal. Can tecplot handle that with time weighted average
Regards Manu |
November 30, 2016, 12:49 |
#4 | |
Peng Yang
Rep Power: 10 |
November 30, 2016, 12:50 |
#5 | |
Peng Yang
Rep Power: 10 |
November 30, 2016, 12:53 |
Manu Chakkingal
Rep Power: 10 |
I ran simulation for sometime again ..checked Delta time... Wrote date at that time step times a whole number...and just averaged by number of time steps saved...I couldn't find any other way
Regards Manu |
November 30, 2016, 13:01 |
Peng Yang
Rep Power: 10 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 15:06 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
