May 20, 2015, 06:26 |
Plotting two plot values in One plot
Bharatesh
Rep Power: 11 |
Hi guys,
I need to plot the Cp values obtained from the experimental results and the CFD computed results in a single plot to compare. The coordinates in the experimental results are (x, y)=(xbyc, neg Cp) where as the coordinates in Computed results are (x, y)=(x, pressure_coefficient). When both the data files are loaded in Tecplot, only the plot for the firstly loaded file is shown, and the secondly loaded file isn't shown. Here, I believe the problem is because of the change in the coordinate names, for to overcome that I followed the below steps: After loading both the files, s1) Data-->Alter-->Specify Equations s2) I equated the variables of X-axis for both files, i.e., V1=V10 (for to achieve x=xbyc) and followed the same step for equating the Y coordinates) s3) Selected the zones of the secondly loaded file s4) Compute s5) Selected the two Zones from both Files After following the above steps, the graph shows a single straight line parallel to Y axis, at 'x=0'. Software version: Tecplot 360 EX 2014 R1 can Somebody help me please!! |
May 22, 2015, 18:15 |
Creating linked Cp curves in Tecplot 360 EX 2015
Scott Rumage
Rep Power: 17 |
Bharatesh, this tutorial video http://172.16.144.14/blog/2015/05/22/linked-cp-curves/ on Tecplot's web-site shows the creation of linked Cp curves may be helpful for your application.
Sorry that I am unable to answer your question directly. Scott |
May 29, 2015, 02:10 |
#3 | |
Bharatesh
Rep Power: 11 |
multiple plots in tecplot |
Velocity values are normal but pressure values are too big | rv82 | OpenFOAM Running, Solving & CFD | 4 | April 13, 2015 04:59 |
Plotting Average Values in Fluent-A solution | syavash | FLUENT | 0 | August 26, 2013 15:28 |
Accessing Mass Fraction Values and Plotting using TUI | ankur_kr | FLUENT | 1 | August 6, 2013 21:44 |
nice plot of boundary layer with experimental values | jack1980 | FLUENT | 0 | May 5, 2010 09:59 |
Interpolation values in nodes and cells | mrestrepo30 | FLUENT | 0 | April 27, 2010 10:20 |
