February 17, 2014, 14:17 |
Fast Fourier Transform (FFT) in Tecplot 360
Wojo Woyczynski
Rep Power: 12 |
Hi All,
I am trying to use Tecplot 360 to get the frequency of my wave. I am using the "Fourier Transform" tool in the "Data" menu. For the plot that gets output, the frequency I am getting looks correct but the amplitude is way higher than the amplitude of my wave. What is problem here? Does anybody know the exact fourier equation that Tecplot 360 uses? Thanks |
May 11, 2014, 06:41 |
Mohsen KiaMansouri
Rep Power: 16 |
Dear Wojo
We have encountered the same problem in Tecplot. The Trend of the output graph and the frequency are very similar to the results obtaind using Excel but the amplitude is very high. If we use different Window function (Rectangular, Triangular, Hann, Hamming) then different amplitudes are obtained but all of them are very High. Have you solved this problem? Thanks in advance
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.” |
May 12, 2014, 13:01 |
Jerimiah
Rep Power: 16 |
Tecplot 360 uses FFTW to perform the FFT calculation. As with most DFT's a gain or scaling factor is introduced. We have chosen to leave the calculation as is and let the user decide if they need it scaled down. If you divide the amplitude by your sampling size, you should receive a more reasonable value. You can use the Data > Alter > Specify Equations tool to do this. |
October 23, 2014, 19:57 |
FFT tutorial link
Scott Rumage
Rep Power: 17 |
Here is a link to a tutorial on performing FFT in Tecplot 360 EX: https://www.youtube.com/watch?v=hDhhpH0fOMA
Scott |
September 21, 2016, 09:04 |
freeday
Rep Power: 16 |
How much I have to scale down? Is there any information about it? Tb4
October 26, 2017, 12:09 |
Kuldeep
Rep Power: 10 |
Generally, You can divide magnitude by number of sample data points to get correct amplitude.
fast fourier transform, fft, fourier, tecplot 360 |
Fast Fourier Transform | alastormoody11 | STAR-CCM+ | 0 | January 20, 2011 23:49 |
Fast Fourier Transform of CL signal | Sachin Paramane | Main CFD Forum | 0 | June 11, 2007 08:51 |
Fast Fourier Transform | Lourival | Main CFD Forum | 21 | June 7, 2007 01:53 |
Fast Fourier Transform | Lourival | FLUENT | 0 | May 16, 2007 15:02 |
Fast Fourier Transform | Sara | Main CFD Forum | 2 | February 14, 2006 08:51 |
