December 16, 2024, 08:31 |
Mesh metric data
Giovanni Bettega
Rep Power: 12 |
a quick question about this metric data. +--------------------------------------------------------------+ | Mesh Quality Metric| Minimum| Maximum| +--------------------------------------------------------------+ | Orthogonality Angle (deg.)| 60.3835| 89.8552| | CV Face Area Aspect Ratio| 1.29375| 689.973| | CV Sub-Volume Ratio| 1.02479| 4.24807e+08| +--------------------------------------------------------------+ What exactly is CV Sub-Volume Ratio and how is it defined? Regards Giovanni |
Yesterday, 12:26 |
Giovanni Bettega
Rep Power: 12 |
/*--- Volume ratio is computed by looping over all volume elements and
computing the sub-element volume contributions. The ratio between the largest and smallest sub-elements making up the dual CV is a measure of the volume stretching ratio for the cell. Smaller is better (closer to isotropic). ----*/ |
mesh |
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 10:49 |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 16:16 |
What is the data structure of an unstructured mesh? | Aerterliusi | Main CFD Forum | 15 | August 3, 2023 08:59 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
