incompressible flow - bulk modulus - Re number |
November 14, 2024, 06:36 |
Giovanni Bettega
Rep Power: 12 |
a couple of very short questions. 1) First question: Incompressible flow simulation: A fluid with density 4.1 [kg/m^3] viscosity 2x10^-4 [Pa s] enters a straight pipe having D = 2.7 [m] diameter, with velocity V = 0.4 [m s^-1]: see picture (mesh of one half of the domain). So Re ~ 2.0 x 10^4 Su2 tells me +------------------------------------------------------------------------------+ | Mach Number| -| -| -| 0.000539562| | Reynolds Number| -| -| -| 2067| +------------------------------------------------------------------------------+ 2) second question: Also the Ma is shown: how this "default" value is computed? Does it comes from the .cfg setting? [...] % Bulk Modulus for computing the Mach number BULK_MODULUS= 1.42E5 Does it share something with the artificial compressibility method in "Simulation and Adjoint-based Design for Variable Density Incompressible Flows with Heat Transfer" [T.D. Economon] and references therein? Thank you very much, in advance Giovanni |
November 18, 2024, 09:13 |
#2 | |
Rep Power: 5 |
Dear Giovanni, Regarding the first question, SU2 computes the Reynolds number assuming REYNOLDS_LENGTH=1.0 you can change that option. Also the options INC_DENSITY_INIT is used for computing the Reynolds number. So the Reynold number is computed based on the free_stream_values which for the incompressible solver are the values provided in the config options that start with INC_...... I think the same applies to your second question. The incompressible solver and preconditioning implemented in SU2 are the ones depicted in the paper that you mentioned. I hope this might help to you. Best regards, Cristopher Morales Ubal |
bulk modulus, re number |
failing to decompose merged meshes | Marcelinus | OpenFOAM Pre-Processing | 0 | May 31, 2024 07:46 |
use the message in macro DEFINE_PROFILE with parallel processor | alireza_T | Fluent UDF and Scheme Programming | 3 | May 11, 2022 03:08 |
Foam-Extend 4.0 simpleFoam motorbike parallel error? | EternalSeekerX | OpenFOAM Running, Solving & CFD | 0 | May 10, 2021 05:55 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 23:29 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
