Home > Forums > Software User Forums > SU2
Restarting simulation does not work
Like Tree2Likes
  • 1 Post By bigfootedrockmidget
Old   October 7, 2024, 11:07
Exclamation Restarting simulation does not work
Sakun
Sakun is on a distinguished road
I am trying to restart the simulation using initial set of data (100 iterations).
So i have set up the .cfg file as follows,
% Output file restart flow
RESTART_FILENAME= flow100.dat
% Output file flow (w/o extension) variables
VOLUME_FILENAME= flow100
And it got simulated without an issue (“Initial data set” picture).
Then I have set,
% Restart solution (NO, YES)
RESTART_SOL= YES
SOLUTION_FILENAME= flow100.dat
But simulation still runs from the 1 to 99 not starting from 99th iteration (“Secondary data set” picture). (Used mpirun -n 12 SU2_CFD naca0012.cfg code to run the simulation).
Any guide is appreciated,
Sakun is offline   Reply With Quote
Old   October 7, 2024, 13:42
bigfoot
bigfootedrockmidget is on a distinguished road
When restarting, the iterations start at 0 again. We do not keep track of the number of iterations of previous runs.
giovanni.medici likes this.
bigfootedrockmidget is offline   Reply With Quote
Old   October 7, 2024, 14:02
Sakun
Appreciate for the clarification
So, I assume same concept apply for the convergence history file as well? Cause when I check that file, it has only recorded from 0 to 99 iteration too.
Is there a way to confirm that simulation is definitely continuing from the previous data file?
Thank you again,
Old   October 7, 2024, 14:17
bigfoot
For simulation 2, the residuals at iteration 0 should correspond to the final residuals of simulation 1.
If you concatenate the old and the new residual file, it should show a continuous line for the residual values, preferably decreasing.
Sakun likes this.
Old   October 7, 2024, 14:53
Sakun
I haven’t tried setting up the residuals/plots yet so I missed that point. Thanks for suggesting me that, it is actually a good tactic.
Can I make residuals recorded in the convergence history file or do I have to generate it in a different file?
Thank you for your help,
post processing, source code, su2
thesis work - microturbine simulation - zero torque Exe FLUENT 0 May 21, 2024 09:53
CFD simulation (using FLUENT) of gas flow in shock tube - Willing to pay for the work selvam2487 CFD Freelancers 0 October 19, 2022 05:19
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 06:28
Restarting a CFX simulation from last stop selvam2487 CFX 9 September 9, 2014 12:00
work piece simulation and analysis anilmnv Main CFD Forum 0 March 27, 2011 14:32
