September 10, 2024, 10:11 |
SU2 ONERA M6 Analysis
Rep Power: 2 |
Hello everyone, I tried to run Turbulent ONERA M6 su2 code (https://su2code.github.io/tutorials/Turbulent_ONERAM6/). However, when I check the results on TechPlot, I get results which makes no sense. Look at the pressure over the wing... Is this problem because of TechPlot or something different?
https://ibb.co/ZKsFgZb |
September 13, 2024, 07:08 |
Rep Power: 2 |
No comment on this?
September 15, 2024, 16:02 |
bigfoot
Rep Power: 18 |
I do not see what the problem is.
The Onera M6 tutorial shows the pressure coefficient and you show the pressure. Can you also plot the pressure coefficient for your simulation and put it next to the result shown in the tutorial? Then it will be more clear if there is an issue. |
cfd, onera m6, su2, techplot |
SU2 Constrained shape design of a transonic inviscid wing Tutorial Runtime Error | ShengZhang | SU2 Shape Design | 0 | May 11, 2024 05:09 |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Optimization Problem of ONERA M6 wing in SU2 | lbfhappy | SU2 Shape Design | 0 | November 10, 2017 08:31 |
Official Release of SU2 V3.2 | economon | SU2 News & Announcements | 6 | April 17, 2015 23:28 |
Tool to download: SU2 post-processing | Combas | SU2 | 2 | June 5, 2014 14:55 |
