Home > Forums > Software User Forums > SU2
SST converges faster than SA
Like Tree1Likes
  • 1 Post By bigfootedrockmidget
Old   August 29, 2024, 06:31
Default SST converges faster than SA
Tomas Perez Zapico
tomaspzapico is on a distinguished road
I have been running a simulation on the NACA 0012 airfoil at Re=6e6 and M=0.3, with first order for the turbulence equations and JST discretisation scheme. Even though SA is a 1-equation model and SST is 2-equations, SST is converging faster (both in iterations and time) than SA, which should not be happening. Does anyone know what is causing this?
tomaspzapico is offline   Reply With Quote
Old   August 30, 2024, 08:00
bigfoot
bigfootedrockmidget is on a distinguished road
SA does not necessarily converge faster in terms of iterations compared to SST. It really depends on the case.
SST has one more transport equation, so if every transport equation costs an equal amount of time, then you would expect SA to be slightly faster in terms of computing time per iteration. I would expect this to be true, because the SA equation is not twice as expensive to compute compared to the k-w equations. But there are case dependent computations, for instance SA needs to compute some wall distance, which might make it more expensive than SST under certain circumstances.
Sakun likes this.
bigfootedrockmidget is offline   Reply With Quote
Old   August 31, 2024, 17:54
na
TKatt is on a distinguished road
You could check the eddy viscosity for example, I could imagine if SST leads to a larger increase in overall viscosity, that might aid convergence.
If it converges faster in Iterations, the faster in overall time is not really that surprising in most scenarios. Following what Mr bigfootedrockmidget, the single iteration might not even be cheaper at all.
If you want to check that, you should look at time per single iteration. Put WALL_TIME in your SCREEN_OUTPUT and look at that. To level the playing field also make sure to have the linear solver doing similar work by e.g. setting LINEAR_SOLVER_ERROR= 1E-16.
TKatt is offline   Reply With Quote
One more time: wall functions - SST CellZone OpenFOAM Pre-Processing 22 June 11, 2021 14:27
Turbulence Model switch RKE to K-omega SST Astan OpenFOAM Running, Solving & CFD 3 April 6, 2019 04:54
General question about SST turbulence model Richard Renaud CFD Freelancers 1 December 19, 2015 05:13
wall treatment k-w SST model in Fluent behest FLUENT 0 December 26, 2014 09:14
Laminar-to-turbulent transition modelling using SST and SST Gamma Theta models ttu004 CFX 3 June 13, 2014 07:43
