Thermochemical non-equilibrium literature with Air-5 gas models |
August 22, 2024, 23:33 |
李以乐
Rep Power: 2 |
Can you provide some thermochemical non-equilibrium literature involving Air-5 gas models(N2,O2,N,O,NO),I want to verify whether the results I ran on su2 (including the distribution of mass fraction for Air-5 gas) are accurate.
August 31, 2024, 19:05 |
na
Rep Power: 8 |
Since your request is rather specific, I cannot answer really well to that.
Usually, on a scientific endeavor, the researcher does their due diligence in terms of modeling before running head-first into simulations (in CFD especially that can also be costly). And I would recommend doing it that way around compared to what you apparently did. I am not here to gatekeep, so here some general directions - the non-equilibrium stuff in SU2 is running under the name SU2-NEMO - so here would be the google scholar result which points you to probably most literature that was done in SU2 with respect to non-eq simulations https://scholar.google.com/scholar?h...su2+nemo&btnG= - if that is not your thing, maybe the SU2 nemo stuff on youtube already gives you an idea, or the right people to search for in literature https://www.youtube.com/results?search_query=SU2+nemo - you could also look at the methods they use in SU2-NEMO and search for those together with your special application in mind and see how the broader scientific community uses that more often than just SU2 https://su2code.github.io/docs_v7/Th...onequilibrium/ I know this is not a direct answer but maybe it points into the right direction. best, tobi |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 22:36 |
Senior Design natural gas and air mixing problem | wagoat01 | FloEFD, FloWorks & FloTHERM | 4 | February 11, 2016 01:51 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
