Dillon Ryan
Rep Power: 0 ![]() |
I have been in the process of trying to get Mutation++ to work with SU2. I have reconfigured the build file with meson setup --reconfigure build -Denable-mpp=true and ran ninja install in the build folder. When I try to run the viscwedge_mpp case I get the error:
SU2CFD: error while loading shared libraries: libmutation_.so: cannot open shared object file: No such file or directory. Is there any advice of how to fix this issue? |
#2 | |
bigfoot
Rep Power: 17 ![]() |
error using mutation++
failing to decompose merged meshes | Marcelinus | OpenFOAM Pre-Processing | 0 | May 31, 2024 06:46 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
