李以乐
Rep Power: 2 ![]() |
I have a question about the selection of RESTART_SOL . I have found that some cases are either YES or NO. I want to know the impact of choosing YES or NO on the calculation process and results, because some of my configuration files filled in YES may cause errors during runtime, but this situation does not occur when choosing NO. |
bigfoot
Rep Power: 17 ![]() |
SU2 can write a file containing the current solution variables, using
OUTPUT_FILES= RESTART Code:
RESTART_FILENAME= restart You can restart from this solution using Code:
RESTART_SOL= YES Code:
SOLUTION_FILENAME= solution So if you have previously saved restart.dat, you can rename that file solution.dat and restart from that file to speed up the time to reach convergence. You can also restart using a different mesh, SU2 will interpolate the solution onto the new mesh using a nearest neighbor approach. |
Duplicate entry alphaContactAngle in runtime selection table fvPatchField | Roesch | OpenFOAM Programming & Development | 2 | January 12, 2021 03:35 |
[ANSYS Meshing] Script Connection Friction | arpeedesign | ANSYS Meshing & Geometry | 4 | April 11, 2019 08:17 |
[ANSYS Meshing] Overlapping Named Selection error though every named selection differs from each othe | Onurozcan | ANSYS Meshing & Geometry | 1 | December 10, 2015 21:49 |
Overlapping Named Selection error though every named selection differs from each othe | Onurozcan | Main CFD Forum | 0 | December 6, 2015 16:12 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
