Rep Power: 8 ![]() |
I am looking to simulate a real gas using a Cp(T) polynomial instead of the constant value of 1004.703 J/kg*K for air. I noticed a line for CP_POLYCOEFFS in the template SU2 file, but I couldn't find any information on how to enable it. Can this be used with the STANDARD_AIR fluid model, or do I need to select a different model? Thanks, |
bigfoot
Rep Power: 17 ![]() |
It can be used when you set the fluid to incompressible polytropic gas.
From config_template.cfg: Code:
% ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % FLUID_MODEL= INC_IDEAL_GAS_POLY SPECIFIC_HEAT_CP= 1004.703 MOLECULAR_WEIGHT= 28.96 CP_POLYCOEFFS= ( 1004.703, 0.1, 0.0, 0.0, 0.0) |
Thank you!
I am looking to simulate compressible flow at high Mach numbers, around Mach 5. Could you recommend a more suitable fluid model for this scenario? I plan to account for variations in the heat capacity ratio caused by the high pressures and temperatures. |
bigfoot
Hi, sorry for the long wait, so you could maybe also use the NEMO solver, which targets hypersonic flows. There are some examples in the testcases repository.
I'll check it, thank you
cp polynomial, real-gas, specific heat |
Fluent UDF - polynomial profile description | mihnea333 | FLUENT | 0 | February 26, 2021 03:19 |
Error: GENERAL CAR CDR - User-Defined-Material-Database | EvaKn | FLUENT | 0 | December 21, 2020 08:01 |
Add piecewise polinomial material property | EvaKn | FLUENT | 0 | December 21, 2020 06:03 |
thermophysicalProperties with polynomial values | Gerrit | OpenFOAM Running, Solving & CFD | 4 | April 21, 2020 10:51 |
polynomial BC from 3d vector data | map | OpenFOAM Programming & Development | 0 | March 30, 2015 08:48 |
