Questions about the tutorial Unconstrained shape design of a two-way mixing channel |
Tongtong
Rep Power: 2 ![]() |
Hello everyone,
While following the SU2 tutorial series' Design Features, specifically the case "Unconstrained shape design of a two-way mixing channel," I encountered an issue during the fourth step, Gradient Validation. My calculation results: ![]() However, the results provided on the website: ![]() The results from these two are vastly different, but the script seems to run normally without any error messages. ![]() After running the program according to the tutorial, the result is obtained in just one step (although no error messages are displayed, this result clearly isn't what was expected). ![]() Is there any issue here? Any suggestions would be greatly appreciated. |
Tongtong
Fortunately, I found the mistake in the first problem. The error was caused by the inconsistency in the finite difference step size between the two scripts. In the gradient_validation.py script, the value was set to 1e-8, while in the postprocess.py script, I had set it to 1e-7 (forgive my oversight).
Questions about simulation free surface open channel flow by interFoam and pimpleFoam | IsanM | OpenFOAM Programming & Development | 0 | September 10, 2020 03:13 |
micro channel heat exchanger design | serpil kaya | Main CFD Forum | 6 | March 25, 2018 07:34 |
STAR-CD tutorial 16(LES of turbulent channel flow) | yss | STAR-CD | 1 | October 15, 2012 14:19 |
manifold to many small channel design | mullenc525 | CFX | 8 | April 4, 2011 19:15 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
