Giovanni Bettega
Rep Power: 11 ![]() |
Hello Forum,
please, consider the following CFL settings, in a .cfg file: % ----------- % CFL number % ----------- CFL_NUMBER= 100 % ------------------------------------------------------------------ % CFL adaptation ON % factor down, factor up, CFL minimum, CFL maximum, limit tolerance % ------------------------------------------------------------------ CFL_ADAPT= YES CFL_ADAPT_PARAM= ( 0.1, 1.1, 1.0, 100, 0.001) Questions: 1) at the very beginning of the run what is the CFL number? The calculation starts with CFL_NUMBER= 100, or CFL minimum? 2) what happens if CFL_NUMBER > CFL maximum or CFL_NUMBER < CFL minimum (example: CFL_NUMBER= 200 CFL_ADAPT= YES CFL_ADAPT_PARAM= ( 0.1, 1.1, 1.0, 100, 0.001) ) Thank you for your help Giovanni |
bigfoot
Rep Power: 17 ![]() |
1. the initial CFL is CFL_NUMBER
2. the initial CFL is bounded using CFL=max(min(CFL_NUMBER,CFL_MAX), CFL_MIN) 3. When CFL hits the bounds, it stays at the bounds unless the simulation destabilizes again. 4. you can observe what happens using SCREEN_OUTPUT= AVG_CFL |
cfl number, cfl specification |
CFL Adapt parameter | DLuo | SU2 | 7 | May 19, 2024 18:28 |
CFL RAMPING IN v 7.1.1 | pdp.aero | SU2 | 4 | May 26, 2021 12:46 |
Is CFL number (or Courant number) omnipotent? | Vignesh2508 | Main CFD Forum | 11 | February 28, 2019 12:56 |
Test Case CFL Number Issues with Software Update | JBCFD | SU2 | 3 | July 14, 2017 12:05 |
CFL ramp option | curky | SU2 | 1 | April 11, 2013 13:25 |
