李以乐
Rep Power: 2 ![]() |
Hello everyone,
I am currently planning to perform verification calculations on a two-dimensional cylinder case , which involves non-equilibrium knowledge points. I observed in a testcase that GAS-MODEL=AIR-7, as my example requires AIR-5. However, I am not sure how many equations are involved in the AIR-5 options. Can I find the relevant parts in the source code? |
bigfoot
Rep Power: 17 ![]() |
air-5 : 5 equations (N, O, NO, N2, O2)
If you are using mutation, then all files with mechanism definitions are in subprojects/Mutationpp/data/ |
李以乐
well,I have reviewed the corresponding cfg file again and found that the fluid model selection is SU2-NONEQ. Can I search for the formula selection for the five component gases corresponding to this model in the source code?
gas_model, su2 |
