lucrezia
Rep Power: 2 ![]() |
Hi, I am trying to do a hypersonic simulation with SU2NEMO, but i get this error:
Mutation++ has not been configured/compiled (add '-Denable-mpp=true' to your meson string) or 2) CODI must be deactivated since it is not compatible with Mutation++. I downloaded Mutation++ from Github and I put it in the su2 folder, but i don't know if I have to do any further procedures. Thank you in advance PS I tried to put -Denable-mpp=true manually on the meson.py but it doesn't seem to solve the problem |
bigfoot
Rep Power: 17 ![]() |
you need the option -Denable-mpp=yes in the meson configuration
you also need to set this variable: Code:
export MPP_DATA_DIRECTORY=$SU2_HOME/subprojects/Mutationpp/data HTML Code:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$SU2_HOME/subprojects/Mutationpp |
lucrezia
Thank you. When you say I need the option -Denable-mpp=yes in which file do I need to put that?
meson.build or meson.py or meson_options.txt ? |
bigfoot
It is an option that you add after the meson command on the command line, so
./meson.py build -Denable-mpp Last edited by bigfootedrockmidget; January 12, 2024 at 14:25. |
hypersonic flow, hypersonics, mutationpp, nemo |
