Home > Forums > Software User Forums > SU2
Discrepancy in Exit Mach Number: Validation with Experimental Nozzle Data
Like Tree1Likes
  • 1 Post By bgulzar22
Old   January 6, 2024, 02:20
Default Discrepancy in Exit Mach Number: Validation with Experimental Nozzle Data
Sean
bgulzar22 is on a distinguished road
I am currently working on validating my CFD results using experimental nozzle data. The experimental conditions specify a total pressure of 517100 Pa, total temperature of 843.33 K, and a wall temperature set to 0.5 times the total temperature. Additionally, the exit Mach number is expected to be 2.5.
However, upon running the simulation with the provided boundary conditions, I am getting an exit Mach number of 1.9 instead of the expected 2.5. I have attached my configuration file for your reference.
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% Physical governing equations (EULER, NAVIER_STOKES,
% FEM_EULER, FEM_NAVIER_STOKES, FEM_RANS, FEM_LES,
% WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY,
% POISSON_EQUATION)
SOLVER= RANS
% Specify turbulence model (NONE, SA, SST)
KIND_TURB_MODEL= SA
SST_OPTIONS= V2003m
% Mathematical problem (DIRECT, CONTINUOUS_ADJOINT, DISCRETE_ADJOINT)
MATH_PROBLEM= DIRECT
% Restart solution (NO, YES)
RESTART_SOL= NO
% System of measurements (SI, US)
% International system of units (SI): ( meters, kilograms, Kelvins,
% Newtons = kg m/s^2, Pascals = N/m^2,
% Density = kg/m^3, Speed = m/s,
% Equiv. Area = m^2 )
% United States customary units (US): ( inches, slug, Rankines, lbf = slug ft/s^2,
% psf = lbf/ft^2, Density = slug/ft^3,
% Speed = ft/s, Equiv. Area = ft^2 )
SYSTEM_MEASUREMENTS= SI
% -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------%
% Mach number (non-dimensional, based on the free-stream values)
MACH_NUMBER= 1E-9
% Angle of attack (degrees, only for compressible flows)
AOA= 0.0
% Side-slip angle (degrees, only for compressible flows)
SIDESLIP_ANGLE= 0.0
% Init option to choose between Reynolds (default) or thermodynamics quantities
% for initializing the solution (REYNOLDS, TD_CONDITIONS)
INIT_OPTION= TD_CONDITIONS
% Free-stream option to choose between density and temperature (default) for
% initializing the solution (TEMPERATURE_FS, DENSITY_FS)
FREESTREAM_OPTION= TEMPERATURE_FS
% Free-stream pressure (101325.0 N/m^2, 2116.216 psf by default)
FREESTREAM_PRESSURE= 517100
% Free-stream temperature (288.15 K, 518.67 R by default)
FREESTREAM_TEMPERATURE= 843.33
% Compressible flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE,
% FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE)
REF_DIMENSIONALIZATION= DIMENSIONAL
% ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------%
% Fluid model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS,
% CONSTANT_DENSITY, INC_IDEAL_GAS, INC_IDEAL_GAS_POLY)
FLUID_MODEL= STANDARD_AIR
% Ratio of specific heats (1.4 default and the value is hardcoded
% for the model STANDARD_AIR, compressible only)
GAMMA_VALUE= 1.345
% Specific gas constant (287.058 J/kg*K default and this value is hardcoded
GAS_CONSTANT= 287.058
% --------------------------- VISCOSITY MODEL ---------------------------------%
% Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY, POLYNOMIAL_VISCOSITY).
VISCOSITY_MODEL= SUTHERLAND
MU_REF= 1.716E-5
% Sutherland Temperature Ref (273.15 K default value for AIR SI)
MU_T_REF= 273.15
% Sutherland constant (110.4 default value for AIR SI)
SUTHERLAND_CONSTANT= 110.4
% Molecular Viscosity that would be constant (1.716E-5 by default)
MU_CONSTANT= 1.21409E-05
% --------------------------- THERMAL CONDUCTIVITY MODEL ----------------------%
% Conductivity model (CONSTANT_CONDUCTIVITY, CONSTANT_PRANDTL).
CONDUCTIVITY_MODEL= CONSTANT_PRANDTL
% Molecular Thermal Conductivity that would be constant (0.0257 by default)
THERMAL_CONDUCTIVITY_CONSTANT= 0.0257
% Laminar Prandtl number (0.72 (air), only for CONSTANT_PRANDTL)
PRANDTL_LAM= 0.72
% Turbulent Prandtl number (0.9 (air), only for CONSTANT_PRANDTL)
PRANDTL_TURB= 0.90
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker)
% Format: ( marker name, constant heat flux (J/m^2), ... )
MARKER_ISOTHERMAL = (WALL, 421.665)
%MARKER_WALL_FUNCTIONS= ( WALL, STANDARD_WALL_FUNCTION )
% Symmetry boundary marker(s) (NONE = no marker)
MARKER_SYM= ( SYMMETRY )
% Riemann boundary marker(s) (NONE = no marker)
% Format: (marker, data kind flag, list of data)
MARKER_RIEMANN= ( INFLOW, TOTAL_CONDITIONS_PT, 517100 , 843.33, 1.0, 0.0, 0.0, OUTFLOW, STATIC_PRESSURE, 29861.76, 0.0, 0.0, 0.0, 0.0 )
%INLET_TYPE= TOTAL_CONDITIONS
%MARKER_INLET = (INFLOW, 843.33, 517100, 1.0, 0.0, 0.0)
%MARKER_OUTLET = (OUTFLOW, 29861.76)
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
% Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRAD= GREEN_GAUSS
% CFL number (initial value for the adaptive CFL number)
CFL_NUMBER= 0.6
% Adaptive CFL number (NO, YES)
CFL_ADAPT= NO
% Parameters of the adaptive CFL number (factor down, factor up, CFL min value,
% CFL max value )
CFL_ADAPT_PARAM= ( 0.1, 2.0, 10.0, 1000.0 )
% Maximum Delta Time in local time stepping simulations
MAX_DELTA_TIME= 1E6
% ----------- SLOPE LIMITER AND DISSIPATION SENSOR DEFINITION -----------------%
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations.
% Required for 2nd order upwind schemes (NO, YES)
MUSCL_FLOW= NO
% Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG,
% BARTH_JESPERSEN, VAN_ALBADA_EDGE)
SLOPE_LIMITER_FLOW= VENKATAKRISHNAN_WANG
VENKAT_LIMITER_COEFF= 0.01
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations.
MUSCL_TURB= NO
% ------------------------ LINEAR SOLVER DEFINITION ---------------------------%
% Linear solver or smoother for implicit formulations (BCGSTAB, FGMRES, SMOOTHER_JACOBI,
% SMOOTHER_ILU, SMOOTHER_LUSGS,
% SMOOTHER_LINELET)
LINEAR_SOLVER= FGMRES
% Preconditioner of the Krylov linear solver (ILU, LU_SGS, LINELET, JACOBI)
LINEAR_SOLVER_PREC= ILU
% Linael solver ILU preconditioner fill-in level (0 by default)
LINEAR_SOLVER_ILU_FILL_IN= 0
% Minimum error of the linear solver for implicit formulations
LINEAR_SOLVER_ERROR= 1E-6
% Max number of iterations of the linear solver for the implicit formulation
LINEAR_SOLVER_ITER= 10
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
MGLEVEL= 0
MGCYCLE= V_CYCLE
MG_PRE_SMOOTH= ( 1, 1, 2, 2 )
MG_POST_SMOOTH= ( 0, 0, 0, 0 )
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 )
MG_DAMP_RESTRICTION= 0.7
MG_DAMP_PROLONGATION= 0.7
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, AUSMPLUSUP, AUSMPLUSUP2, HLLC,
% TURKEL_PREC, MSW, FDS)
CONV_NUM_METHOD_FLOW= ROE
% Entropy fix coefficient (0.0 implies no entropy fixing, 1.0 implies scalar
% artificial dissipation)
ENTROPY_FIX_COEFF= 0.01
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT)
TIME_DISCRE_FLOW= EULER_IMPLICIT
% -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------%
% Convective numerical method (SCALAR_UPWIND)
CONV_NUM_METHOD_TURB= SCALAR_UPWIND
% Time discretization (EULER_IMPLICIT)
TIME_DISCRE_TURB= EULER_IMPLICIT
% Reduction factor of the CFL coefficient in the turbulence problem
CFL_REDUCTION_TURB= 1.0
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
% Number of total iterations
ITER= 1000000
% Min value of the residual (log10 of the residual)
CONV_RESIDUAL_MINVAL= -24
% Start convergence criteria at iteration number
CONV_STARTITER= 10
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
% Mesh input file
MESH_FILENAME= Mesh.su2
% Mesh input file format (SU2, CGNS)
MESH_FORMAT= SU2
% Mesh output file
MESH_OUT_FILENAME= mesh_out.su2
% Restart flow input file
SOLUTION_FILENAME= solution_flow.dat
% Output file format (TECPLOT, TECPLOT_BINARY, PARAVIEW, PARAVIEW_BINARY,
% FIELDVIEW, FIELDVIEW_BINARY)
TABULAR_FORMAT= CSV
% Output file convergence history (w/o extension)
CONV_FILENAME= history
% Output file restart flow
RESTART_FILENAME= restart_flow.dat
% Output file flow (w/o extension) variables
VOLUME_FILENAME= flow
VOLUME_OUTPUT= (HEAT_FLUX,TEMPERATURE,PRESSURE, MACH NUMBER)
OUTPUT_FILES=(PARAVIEW_MULTIBLOCK,PARAVIEW, TECPLOT)
% Output file surface flow coefficient (w/o extension)
SURFACE_FILENAME= surface_flow
% Writing solution file frequency
OUTPUT_WRT_FREQ= 1000
% Screen output
SCREEN_OUTPUT= (INNER_ITER, RMS_DENSITY, RMS_TKE, RMS_DISSIPATION)
bgulzar22 is offline   Reply With Quote
Old   January 8, 2024, 03:55
Default No reply in 2 days.
Sean
I don't understand why this thread is not addressed yet ?
Old   January 8, 2024, 05:28
bigfoot
bigfootedrockmidget is on a distinguished road
Dear Sean,
Please understand that the SU2 community is an open source community run by volunteers and the researchers answering questions on cfd-online do that on a voluntary basis.
It might be that your question is difficult to answer, does not contain enough information to give an answer (please see: Guide: How to ask a question on the forums)
or that 2 days is simply not enough time to expect a response, especially considering that it was asked in the weekend.
My rule of thumb is that you can only expect a (high quality) answer if you ask a high quality question. Just giving a config file and saying that it does not give you the expected result is not sufficient.
You might consider adding:
1. which case you are trying to simulate, preferably with a reference to a website or journal paper.
2. A link to the mesh or additional results so the problem can be reproduced by the reader. Note that most people will not take the effort to submit a 500M cell mesh to a cluster just to help answering a problem, so the problem should be small.
3. What you tried yourself to investigate the problem: Converged? Mesh-independent solution? Setup according to literature?
Hope this helps.
bigfootedrockmidget is offline   Reply With Quote
Old   January 8, 2024, 05:45
Sean
Originally Posted by bigfootedrockmidget View Post
Dear Sean,
Hope this helps.
Dear bigfoot,
I appreciate your response and the insights you provided regarding the SU2 community on cfd-online. I understand that the community is driven by volunteers, and I want to express my gratitude for the effort put into answering questions.
As a new member seeking insights, I also value the importance of asking high-quality questions to receive meaningful responses. I acknowledge your suggestions on providing additional information, and I will make an effort to improve the clarity and detail of my future queries.
While I understand that it may take time to address complex questions, I was hoping to receive some guidance or suggestions to steer me in the right direction. I am eager to learn and contribute to the community, and any assistance or inquiries related to my initial post would be greatly appreciated.
Old   January 8, 2024, 07:17
bigfoot
Maybe you can tell us which case you are simulating [supersonic wedge?].
Maybe you can tell us which data you have found that you are comparing to so we can check the physics setup.
Old   January 8, 2024, 07:58
Sean
Thank you for your response, I am validating with Back, L. H., Massier, P. F., and Gier, H. L., “Convective Heat Transfer
in a Convergent–Divergent Nozzle,” International Journal of Heat Mass
Transfer.(CASE 262)
A converging–diverging nozzle with a throat diameter of 0.0458 m and
an exit diameter of 0.1227 m. High-pressure air was heated by the
internal combustion of methanol and flowed along a cooled constant
area duct with a length of 0.4572 m and a diameter of 0.355 m before
entering the nozzle.
The gas could be treated as a calorically perfect
gas with a ratio-of-specific heats γ of 1.345. The nozzle exit Mach
number was approximately 2.5. The molecular viscosity and thermal
conductivity were assumed to vary according to Sutherland’s law.
Old   January 8, 2024, 08:05
Sean
And the mesh can be found in the following link
https://drive.google.com/file/d/1CAS...usp=drive_link
Old   January 8, 2024, 08:34
bigfoot
Thanks. The link has restricted access, can you open access to everybody?
Can you share figures where you compare your simulations with the measurements?
Old   January 8, 2024, 09:27
bigfoot
One thing I noticed is that this is a round nozzle, you can simulate it in 2D with axisymmetry, so you need to set AXISYMMETRY=YES
But you need to then set the turbulence model to SST because we did not implement the axisymmetric terms for SA.
Old   January 9, 2024, 02:09
Sean
Dear bigfoot,
Thank you for this suggestion. Earlier I was using axisymmetric condition with SA model but my simulation used to fail. Now following your suggestion, as I could see, I am getting Mach number 2.4 (simulation is still running) , It seems convincing. Earlier I used to get Mach 1.9 only. Once simulation is over and let me compare my results, I will update here.
Old   January 9, 2024, 03:51
Giovanni Medici
giovanni.medici is on a distinguished road
Sorry for the slight detour on this topic, but I noticed that in the configuration FREESTREAM_TEMPERATURE= 843.33 (K) which is the total_temperature, not the static one.
The SU2 documentation is not strictly univocal as, for example in : SU2 Physical Definition FREESTREAM_TEMPERATURE is referred as static temperature, while in NICFD_nozzle tutorial it is referred as stagnation temperature (and I can tell that this tutorial is somewhat similar to the run @bgulzar22 is carrying out).
I understand that this parameters drive the initialization of the simulation, so at the end, the solution will be driven by the Boundary Conditions, anyways, can anybody please check/clarify on that?
Ok, nevermind, I noticed that the MACH_NUMBER is close to 0 so the configuration is initializing with stagnation conditions the flow ( total pressure and temperature, 0 velocity), and then let expand out ...
Last edited by giovanni.medici; January 9, 2024 at 04:20. Reason: I noticed the MACH_NUMBER in the configuration
giovanni.medici is offline   Reply With Quote
Old   January 9, 2024, 04:33
Sean
It might be because, mach number at the inlet of the nozzle is around 0 , so flow is static , so at this stage stagnation pressure will be equal to static pressure.
giovanni.medici likes this.
Old   January 9, 2024, 05:28
cristopher_morales is on a distinguished road
Hi, The freestream temperature is used to initialize the solution. In general, the freestream conditions are used as initial solution.
cristopher_morales is offline   Reply With Quote
Old   January 9, 2024, 06:40
bigfoot
Let us know the progress, would be nice to see some more comparison with the measurements.
internal flow, mach number, nozzle flow
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 21:06
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
