xiaolong li
Rep Power: 3 ![]() |
Hi professor,
I want to use SU2 to simulate a supersonic axial compressor cascade. The 3D mesh file is obtained using autogrid5. And I edit a .cfg file and then compile in CMD. Then, I got a problem as "CGNS reader currently incapable of handling more than 1 database." Is that suggest that SU2 can not simulate 2D model? |
bigfoot
Rep Power: 17 ![]() |
It complains that you have more than one database in the cgns file. You have to limit the cgns to a single database with one mesh. If you need more than one mesh then convert them individually to su2 meshes first.
#3 | |
xiaolong li
Two confusions for this: a) What does database mean? Single database means 2D mesh? b) How to Convert the cgns file to su2 file, maybe pointwise? |
bigfoot
A database contains a mesh and possibly also the solution on the mesh. If you have multiple databases, you probably have multiple meshes inside one cgns file.
Here is some more high-level info, for more details you can visit the cgns website: https://cgns.github.io/CGNS_docs_cur...99-Reno-vg.pdf You can convert cgns files with su2. But you still need to write one database per file. This looks like a problem with the creation and writing in autogrid, so maybe check the user documentation of autogrid on this issue. |
#5 | |
xiaolong li
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
