December 13, 2023, 05:22 |
Configuration for
Ferdinand
I am working on a simulation of a reentry burn of a rocket. I would be very grateful if you could help me on these following points: The main problem I have is to assign two different fluids: air for the free stream conditions and exhaust gaz for the rocket's engines MARKER. Is creating two zones a better option or could I (and in that case how), simply apply a boundary condition to the MARKER engine with specification like gaz composition (H20 88%, OH 7%, H 5%), vapor state, and specific Mach number, temperature and pressure. I did simulation with MARKER_SUPERSONIC_INLET= (Engines, 1580, 60000, 2988,0,0) which works but it's air. Is there any other fluid that could approximate at least if I can't have these precise spec. I tried creating two zones but the simulation diverges directly when running first independently each zone, I think because a bad mesh quality. Could I maybe create two zones and for the second zone (the engine one) just define a boundary on which I can apply the desired conditions. Also, for supersonic flows, which of REYNOLDS or TD_CONDITIONS is more appropriate ? % for initializing the solution (REYNOLDS, TD_CONDITIONS). I am not sure how to choose an appropriate CFL number for the simulation. Should I use adaptative CFL ? I put REYNOLDS_LENGTH= 1.00 which looks strange to me as the rocket has much bigger dimension but when I try to put the REYNOLDS_LENGTH=diameter, the simulation won't work REYNOLDS_LENGTH= 5.00 . Could you advise me on this please. You can find attached the file: testcfg, which works but is too simplified because of the engine BC problem, so that you can get an idea. A big big thank for your help, really appreciate it! Ferdinand |
December 14, 2023, 07:17 |
bigfoot
Rep Power: 18 |
For this, the NEMO solver is most appropriate. You need to compile SU2 with the additional meson option Code:
-Denable-mpp When you compiled SU2 with mutation support, you can first try the nonequilibrium testcases in the repository to see if everything works as expected. |
AMD Genoa best configuration for 128 cores Fluent/Mechanical licenses | chefbouza74 | Hardware | 10 | February 22, 2023 11:45 |
Configuration of my first CFD machine! | AleDP | Hardware | 6 | December 16, 2020 12:35 |
CFD workstation configuration calling for help 2 | Freewill1 | Hardware | 6 | July 8, 2020 21:17 |
[OpenFOAM.org] Cannot open configuration file mpicc-wrapper-data.txt mpicc: Not found | wenjuny | OpenFOAM Installation | 0 | November 25, 2019 09:01 |
Multiple Configuration Simulation | Tristan | CFX | 0 | November 13, 2009 23:01 |
