Seeking Guidance on Divergence Issues in Rocket Nozzle Flow Simulation for Heat Flux |
December 13, 2023, 00:44 |
Sean
Rep Power: 3 |
Hello SU2 community,
I hope this message finds you well. I am currently working on simulating the flow in a rocket nozzle with an isothermal wall condition to calculate heat flux along the wall. Despite my efforts, I have encountered divergence issues in my simulations. Here are the details of my setup: Physics: Rocket nozzle flow simulation with an isothermal wall condition. Numerics:
I am reaching out to seek your valuable guidance on the following: Recommendations for Stability:
Mesh Considerations:
Solver Settings:
Validation Strategies:
I appreciate any guidance or suggestions you can provide to help me overcome the divergence issues and obtain accurate heat flux results along the wall. Thank you in advance for your assistance. Best regards. |
December 13, 2023, 04:48 |
Shukai Wang
Rep Power: 3 |
hi, may you attach your cfg file so that we can take a look? that would be more convenient. thx.
December 13, 2023, 05:09 |
bigfoot
Rep Power: 21 |
Also the mesh, so we can reproduce your issue.
December 13, 2023, 05:24 |
Here are the links of the mentioned files
Sean
Rep Power: 3 |
December 14, 2023, 01:18 |
Sean
Rep Power: 3 |
December 14, 2023, 23:12 |
Sean
Rep Power: 3 |
I am stuck on the same problem, Can anyone suggest from the experience anything atleast ?
December 15, 2023, 05:11 |
bigfoot
Rep Power: 21 |
I had a brief look at it. It does not blow up when you switch off the MUSCL scheme, but the residuals at the wall stay very high for the energy equation.
If you switch from temperature to heat flux, this issue at the wall disappears. Not sure what the origin of this issue is, maybe it's related to the setup of the NICFD, I am not really familiar with it. Does this work for a regular ideal gas? |
diverged, heat flux, isothermal wall, nan error, nozzle flow |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 5 | November 22, 2024 07:32 |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 18:22 |
Nozzle Flow - Divergence Problem | Ijaz | FLUENT | 9 | January 11, 2014 05:36 |
Nozzle Flow Simulation | Winnie | CFX | 0 | August 24, 2007 11:10 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 02:45 |
