Programs / methods to collapse quasi-2D grid to 2D for SU2 7.5.1? |
#1 | |
A Roy
Rep Power: 4 ![]() |
Hello SU2 community,
I am running some 2D transition bubble simulations to compare to experiment and I have CGNS meshes generated by pyHyp; but pyHyp is tailored towards ADFlow resulting in quasi-2D (1-cell thick) meshes and ADFlow's released versions don't appear to have a transition model despite some academic work on developing it. SU2's mesh file section on the user guide mentions: Quote:
Thank you for the help! |
bigfoot
Rep Power: 17 ![]() |
I don't know of open source tools that can do this, but if the geometry is simple, why not reconstruct it in 2D in e.g. gmsh? There are also very nice specialized meshing tools like this one for airfoils: https://github.com/OpenOrion/parafoil
A Roy
I hadn't realized gmsh exports to native SU2 format, will definitely check that out for 2D tri mesh requirements, thank you!
In regards to my original query, I have found an open source but fairly convoluted solution to my original problem for which I'll leave some steps below if anyone stumbles upon this specific problem (structured or unstructured 2.5D mesh to unstructured 2D) and needs some guidance. I use a combination of openfoam's mesh conversion tools, Paraview, and an open source suite of mesh augmentation tools by ONERA called Cassiopee to get this to work. 1. Output structured grid in plot3d format (pyHyp can write to plot3d using the writePlot3D method). 2. Use openfoam's plot3dToFoam function to convert the structured 2.5D plot3d grid to an unstructured grid. 3. Open the openfoam grid in Paraview and either: - Use the autoPatch function (splitting at 30 degrees seems to work decent for most of my airfoil operations at least) in openfoam to create surface patches. Then load just a symmetry patch (i.e. a true 2D slice), and use File --> Save Data and save as a CGNS file. - For more control, use the Slice filter in Paraview to control where to take the slice from (say a 2D section of a wing from a true 3D grid is required or something), then save the slice as a CGNS file making sure the slice is active in the pipeline browser. 4. Import the CGNS slice into Cassiopee's mesh representation, extract the boundary zones, name them, and merge the connectivity to the interior mesh. *** This part is the least flexible of the steps as my implementation requires a parametric definition to isolate the boundary zones. This is trivial for an o-grid such as my specific case, slightly harder for a c-grid/bounding box, quite a bit harder for multi-element airfoils, and significantly difficult for truly complex 2D geometry *** 5. Export the marker-denoted CGNS file in ADF format, and use for SU2 as required! I've attached a sample Cassiopee script for step 4...but by any means it is the most involved step, especially for actually complex geometry. |
mesh, mesh 2d |
Fixed grid methods for compressible viscous flow | liujmljm | Main CFD Forum | 1 | November 7, 2010 17:54 |
grid generation methods | aya | CFX | 3 | October 15, 2008 09:33 |
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM | kenn | Main CFD Forum | 2 | July 18, 2004 18:28 |
Unstructured grid finite volume methods | Marcus | Main CFD Forum | 3 | December 5, 2000 00:25 |
Numerical methods for discontinuous grid interfaces? | Hansong Hang | Main CFD Forum | 12 | September 16, 1998 22:26 |
