March 13, 2023, 10:27 |
Creating a mesh for SU2 in Python
Costas
Rep Power: 3 |
I have written a script using the Gmsh API in Python that creates a .msh file for my geometry and mesh. Previously, when creating a mesh in Gmsh, I have created a .geo file which I then exported to .su2 format and that has worked in SU2 for running simulations. But when I try to export the .msh file to .su2 format and run the simulation, it gives this error message (attached below) - there is no definition for NMARK. My python script is also attached below (i and j are variables that can be altered to change the shape of the bezier curve). I am new to using Gmsh and SU2 in Python so if anyone could spot what I am doing wrong, that would be much appreciated! Many thanks, Costas |
May 29, 2023, 05:51 |
I would like to know how su2 and suave are integrated thanks
zhaoshuchang
Rep Power: 3 |
I WOULD LIKE TO KNOW HOW SU2 AND SUAVE ARE INTEGRATED THANKS
I would like to know how you install SU2 on windows and what is it with python API Thank you |
May 29, 2023, 05:52 |
zhaoshuchang
Rep Power: 3 |
May 30, 2023, 06:11 |
bigfoot
Rep Power: 21 |
The documentation is here:
https://su2code.github.io/docs_v7/home/ |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 10:29 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 18:36 |
[ICEM] Creating unstructured mesh and setting mesh sizes | cfdworks | ANSYS Meshing & Geometry | 0 | February 25, 2014 23:23 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
