Difference between discrete and continuous adjoint? |
March 12, 2023, 03:45 |
Drean
Rep Power: 3 |
Hi all. Is there some documents I can read that can explain the difference between discrete and continuous adjoint methods use by SU2? Lower level one will be better since I am newbie.
March 12, 2023, 06:59 |
bigfoot
Rep Power: 21 |
Here is a long list of publications about SU2, discrete and continuous adjoints
https://su2code.github.io/publications.html Perhaps this presentation about discrete adjoints: https://su2code.github.io/documents/su2_dev_gauger.pdf And this recent 'introduction' youtube video: https://www.youtube.com/watch?v=k_PKjlWbH14 This one for the continuous adjoint method for compressible flows: https://stuff.mit.edu/afs/athena/sof...-2015-1946.pdf You need to know a bit about partial differential equations and computational fluid dynamics. Basically you need the background of at least a BSc. in a STEM field to be able to go through this. So I hope 'newbie' means you are at that level or you will have a hard time. |
March 12, 2023, 07:09 |
Drean
Rep Power: 3 |
Hi bigfootedrockmidget. Yes, seems like I will have a hard time fore sure but thank you so much for the help.
March 13, 2023, 06:35 |
Ole Burghardt
Rep Power: 10 |
The adjoint equations we solve in SU2 are for problems in gradient/sensitivity computation, and they are, therefore, based on a linearization of the (e.g. Navier-Stokes, Euler, ..) equations.
If we want to implement a linearization of those equations, we can either derive them on paper and then go implement the formulas just like the non-linearized flow formulas ("continuous" method, as derived in the context of function spaces); or we can linearize our implementation (i.e. linearize the discretization -> discrete method). The latter is done almost automatically in SU2 via algorithmic differentiation. Hope this helps :-) |
continous adjoint, discrete adjoint, su2 |
Discrete adjoint cannot be run in parallel if variable load actuator disc model used | FabianBueeler | SU2 Shape Design | 1 | June 23, 2023 16:56 |
SU2 Discrete Adjoint Error!!!! | vishu343 | SU2 | 4 | October 15, 2019 19:55 |
Discrete vs Continuous Adjoint solution variable: Scaling/normalization issue? | asitav | SU2 | 2 | November 21, 2018 20:11 |
Urgent - Perform an DISCRETE adjoint analysis in parallel_computation | JPBLourenco | SU2 | 1 | April 23, 2018 11:38 |
Discrete Adjoint giving garbage values | Manish Kumar Mishra | SU2 | 1 | March 7, 2018 16:35 |
