Home > Forums > Software User Forums > SU2
convert optimized airfoil mesh to geometry?
Like Tree1Likes
  • 1 Post By bigfootedrockmidget
Old   March 7, 2023, 05:46
Post convert optimized airfoil mesh to geometry?
Ming Yang ,Lin
danielncku is on a distinguished road
Greeting to all,
I 'm currently doing 2-D airfoil shape optimization, and after the optimization process was finished, SU2 will give me an optimized airfoil mesh(.su2), but i was unable to find a way to transfer my airfoil to a CAD file format(.stp, .igs ...).
I wanna ask you guys about if you ever encounter this problem?and how to make it happend?
Thanks,
daniel.
danielncku is offline   Reply With Quote
Old   March 7, 2023, 06:15
bigfoot
bigfootedrockmidget is on a distinguished road
You can take the paraview result and export it to an STL. you can then load it in a CAD cleaning software, for instance Pointwise (Pointwise can also load su2 files directly). You remove the triangulation and keep only the surface information. You can merge the discrete surface into one surface again and remesh.
danielncku likes this.
bigfootedrockmidget is offline   Reply With Quote
Old   March 7, 2023, 07:29
Ming Yang ,Lin
Originally Posted by bigfootedrockmidget View Post
Thanks for the reply, I will try it out right away.
cad, geometry, su2
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Mesh geometry over airfoil with Gambit laith FLUENT 5 March 9, 2018 02:56
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 06:26
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
