January 31, 2023, 12:02 |
Heat Source Implementation Issues
Hello everyone,
I am wondering if anyone on here has experience with successfully implementing a source term in the flow on SU2? I've had success in imposing a heat source in simple-2D inviscid and viscous cases, in addition to the 3D inviscid case, but the source doesn't work in 3D viscous cases. It also doesn't appear when the mesh contains irregular geometry (i.e. shock wedge/generator). Would anyone know why this might be happening? |
February 1, 2023, 08:13 |
bigfoot
Rep Power: 18 |
For detailed code discussions, please use github and share your implementation so everybody can have a look and reproduce your results.
For this discussion, see https://github.com/su2code/SU2/discussions/1904 |
modification, source, su2 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
