Can SU2 output the thermal conductivity field and diffusion heat flux on the wall? |
January 13, 2023, 21:06 |
Dengke Li
Rep Power: 3 |
Hello all,
I am new to SU2. And I want to use it to do a simulation of a hypersonic cylinder flow with a catalytic wall boundary condition. I can only get the total wall heat flux now, but the diffusion heat flux is also important. So anyone knows how to output the diffusion heat flux? And if possible, I also want to output the thermal conductivity, diffusion flux, and total enthalpy fields. Any help will be appreciated. |
January 14, 2023, 08:04 |
PENG YAN
Rep Power: 5 |
Just read SU2_CFD/src/output/CFlowCompOutput.cpp, learn how Pressure is output.
Then you can modify the code and output anything you want. Best wishes. |
January 14, 2023, 08:05 |
Dengke Li
Rep Power: 3 |
January 15, 2023, 03:51 |
bigfoot
Rep Power: 18 |
January 15, 2023, 04:23 |
#5 | |
Dengke Li
Rep Power: 3 |
January 15, 2023, 04:37 |
#6 | |
Dengke Li
Rep Power: 3 |
January 15, 2023, 05:57 |
bigfoot
Rep Power: 18 |
yes, if the variable can be retrieved from Node_Flow, you do this in SetVolumeOutputValue:
Cp: Node_Flow->GetSpecificHeatCp Cv: Node_Flow->GetSpecificHeatCv For development, I recommend using vscode. It also has autocomplete, so if you type Code:
Node_Flow-> Code:
Node_Flow->GetSpecificHeatCp EDIT: the available variables depend on the solver, not every solver has the same functionality Last edited by bigfootedrockmidget; January 17, 2023 at 15:54. |
January 15, 2023, 06:15 |
#8 | |
Dengke Li
Rep Power: 3 |
January 17, 2023, 08:49 |
#9 |
Wally Maier
Rep Power: 7 |
Hi All,
In NEMO, gamma is stored in at the node level and can be accessed via: "Node_Flow->GetGamma(iPoint)" On the other hand the Cp and Cv functions do not exist |
January 17, 2023, 09:01 |
#10 | |
Dengke Li
Rep Power: 3 |
Thanks for the reminder. So that's the point. For I just found that when I add Cp and Cv in the outputs it always returns a zero constant flowfield. |
January 17, 2023, 09:50 |
#11 | |
Dengke Li
Rep Power: 3 |
When I use "Node_Flow->GetGamma(iPoint)" to get Gamma. It reminds me that "class "CVariable" has no member "GetGamma". Then I add GetGamma() in CVariable.hpp via "inline virtual su2double GetGamma(unsigned long iPoint) const { return 0.0; }" "inline virtual void SetGamma(unsigned long iPoint, su2double Gamma) {}" But it doesn't work. The Gamma in output is always 0. |
January 17, 2023, 11:53 |
#12 |
Wally Maier
Rep Power: 7 |
Hmmm,
The GetGamma function (for your use) is only defined in the NEMO solver: " /*! * \brief Returns the stored value of Gamma at the specified node */ inline su2double GetGamma(unsigned long iPoint) { return Gamma(iPoint); } " |
January 17, 2023, 16:13 |
#13 |
bigfoot
Rep Power: 18 |
Yes, It's a bit confusing because GetGamma() is part of the CNEMOEulerVariable class, but in the NEMO output, the flow_nodes belong to CVariable, so it's a bit more complicated than simply adding 2 lines.
January 18, 2023, 06:26 |
#14 | |
Dengke Li
Rep Power: 3 |
Could you give me some tips to allow GetGamma() used in NEMO output? |
UDF for electric flux in diffusion | Achini | Fluent UDF and Scheme Programming | 2 | April 25, 2021 01:30 |
Coupled Heat and Mass Transfer | Mecroob | OpenFOAM Running, Solving & CFD | 1 | July 12, 2020 19:24 |
Turbulent Diffusion for Temperature Equation | Tobi | OpenFOAM Programming & Development | 6 | July 8, 2019 03:28 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
