Esdras
Rep Power: 3 ![]() |
Hey guys, I just installed pyAMG and switched to the feature_adapt branch of SU2, I then tried running the first example showed in the SU2 examples section of the pyAMG page and this error comes up, I'm honestly at a loss. I know it's not the configuration file as I literally just downloaded it from the example page, any help would be highly appreciated.
Some background info: At first I was having problems because for some reason the _amgio module wasn't installed, but I solved that problem by following the instructions in this forum: https://github.com/su2code/SU2/discussions/1700 f7c76cf2-2b8b-4ce5-9df4-e1bcc43a4f56.jpg |
PENG YAN
Rep Power: 5 ![]() |
I think the error message is very clear, you miss some options in the config file.
Try to add these options in your config and run it again: % ------------- MESH ADAPTATION PARAMETER ------------% % Type of sensor used for adaptation. Options include GOAL (adjoint-based), MACH, PRES PYADAP_SENSOR= MACH % Maximum cell size for adaptation PYADAP_HMAX= 500.0 % Minimum cell size for adaptation PYADAP_HMIN= 1e-9 % Gradation factor (typically 1.2-1.8) PYADAP_HGRAD= 1.8 % Norm used for adaptation % 1.0 or 2.0 recommended for inviscid flows % 4.0 recommeneded for viscid ADAP_NORM= 2.0 % Approximate mesh size (NPOI) at each level PYADAP_COMPLEXITY= (30000, 60000, 120000) % Number of adaptations performed at each level PYADAP_SUBITE= (3, 3, 3) % Value for ITER for the flow solver at each level PYADAP_FLOW_ITER= (2999, 4999, 6999) |
Giovanni Medici
Rep Power: 12 ![]() |
Dear Esdras,
which branch are you currently working with? feature_adap, if I recall correctly was a relatively stable one, but the last update was like 3 years ago. So I'd say it is stuck to 7.0.3. |
error, pyamg |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
Creating labelList from cells with certain attribute | juhuettn | OpenFOAM Programming & Development | 8 | November 10, 2019 23:06 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
