No slope limiter on problems involving shocks? |
January 9, 2023, 20:19 |
Anders Aamodt Resell
Rep Power: 4 |
I had a look at the SU2 tutorials and notices something that seemed strange to me. For the case "inv_wedge_HLLC" no slope limiter is used, even though this is a supersonic case involving shocks. Could someone please explain why it is set up like this? I have long had the impression that slope limiters were necessary at discontinuities to avoid spurious oscillations, but are less important in smooth regions. Does this only apply to explicit solvers?
January 10, 2023, 19:15 |
Wally Maier
Rep Power: 7 |
Hi Ander,
Your reasoning is valid. However, these oscillations can depend on the convective numerical scheme and the flow problem itself. The wedge test case isn't a validation case, so the impact of any numerical instabilities isn't much of a concern. Hope that helps, Wally |
January 11, 2023, 10:02 |
Rep Power: 4 |
Thanks for your reply, however I don't think everything is addressed yet.
My understanding is that the wedge flow case is basically a Riemann problem with a transverse velocity component, where the analytical solution is known. Using HLLC with Muscl scheme for Riemann problems did require slope limiters based on my previous experience. If oscillations were present, I guess the solution wouldn't converge as well as it did in this case. Would be interesting to hear the reasoning behind it from the person that set up the case. |
January 11, 2023, 10:32 |
Wally Maier
Rep Power: 7 |
Correct, the analytical solution is known and the tutorial may not exactly match said solution. The tutorial problem is meant to serve as a baseline to set up supersonic flows, not necessarily serve as a validation case.
The oscillations, if large, could limit the converges or degrade solution quality. Limiters are not a necessity to simulate/converge supersonic problems but do provide better accuracy. As for the person who wrote that tutorial, I imagine they have since moved on from working on SU2. |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Problems using reconstructPar on a case involving AMI | Kaskade | OpenFOAM Running, Solving & CFD | 38 | September 30, 2020 06:36 |
Problems launching adjoint | max_ | SU2 | 2 | March 12, 2016 11:32 |
Limiter MINMOD' problems | akun646 | SU2 | 3 | August 28, 2014 15:24 |
Problems involving interFoam and GCC 410 | gschaider | OpenFOAM Installation | 1 | July 30, 2006 19:58 |
