Home > Forums > Software User Forums > SU2
SU2 stuck at 'Geometry Preprocessing'
Like Tree1Likes
  • 1 Post By cg102
Old   December 29, 2022, 17:39
Default SU2 stuck at 'Geometry Preprocessing'
Costas
cg102 is on a distinguished road
I'm trying to run some simple simulations of an ogive in supersonic flow using SU2. I've created the mesh in Gmesh and modified the config file from the inviscid wedge tutorial (attached).
The simulation has worked when I tried a wedge as in the tutorial (and even with complex multi-element wedges) but doesn't work for the ogive or any shape with a curved surface - it gets stuck at the 'geometry preprocessing' step (screenshot attached). I can't see anything that should make a difference in the simulation between the wedge and ogive so not sure why it's not working.
If anyone could assist, that would be much appreciated. Let me know if i need to provide any more detail!
Many thanks in advance,
Costas
cg102 is offline   Reply With Quote
Old   December 30, 2022, 04:58
pcg
Pedro Gomes
pcg is on a distinguished road
In gmsh you need to create physical groups for all surfaces and volumes, and then when you export do not click "export all".
Upload your mesh.
pcg is offline   Reply With Quote
Old   December 30, 2022, 07:07
Costas
Thank you for your response. I tried that but then I get other errors. And the mesh file doesn't look right if I don't click 'save all elements'? See attached (it's a .su2 file but been converted to text for upload)
Thanks,
Costas
Old   December 30, 2022, 08:06
bigfoot
bigfootedrockmidget is on a distinguished road
You have 0 elements, this typically happens when you forget to add the 2D domain/surface as a physical group. Please check this, if you have more issues then please post the .geo file.
bigfootedrockmidget is offline   Reply With Quote
Old   December 31, 2022, 10:30
Costas
Ok I've added a surface physical group and called it 'Surface'. The transfinite mesh seems to be fine? (the text file is too large to post and I don't think I can post a .geo file on here?).
But now because I have 'Surface', I get the error message 'config file has no marker definition for marker "Surface"'.
Do I need to change something in the config file (attached) to accommodate this?
Note, in the screenshot, the 'Wall' is the upper, lower and ogive lines. The 'Inlet' is the left line, and the 'Outlet' is the right hand line.
Thanks.
Old   January 2, 2023, 07:58
bigfoot
Hi, Please post the geo file as a .txt file so we can reproduce the issue. The surface should not be present as a marker, so there is still something wrong. Is the option 'save all elements' deselected?
Old   January 2, 2023, 10:05
Costas
Hi, ok I have attached it below. Yes the 'save all elements' is deselected when I export it to .su2.
Thanks
Old   January 2, 2023, 15:35
bigfoot
If I load this geo file in gmsh and export it to an su2 file, then SU2 runs for the config file that you've sent earlier. Maybe it's now a matter of making sure that you're using the right files.
Old   January 3, 2023, 07:14
Costas
Ok, I will check my files. When you say the surface shouldn't have a marker, how can you create the physical group without a marker? I tried to run the files I posted that you have just run and I get this error (attached).
Old   January 3, 2023, 09:12
bigfoot
gmsh should not export the physical surface as a marker for 2D meshes. The only thing I did was load the geo mesh, click '2D Mesh' to generate the mesh, and then export to su2 format. When I inspect the su2 mesh, I only have 3 markers: inlet, outlet and wall.
Old   January 3, 2023, 09:27
Costas
Ok I have done that but it still has surface as a marker. However, I changed NMARK in the mesh file to 3 (from 4) so it doesn't count the last marker. It now works and I get results. Not sure why it still counts 4 markers but for the few simulations I'll be running, it won't be too onerous to change NMARK each time.
Thank you very much for your help!
Old   January 4, 2023, 11:38
bigfoot
Nice to see that you figured out a way to produce the mesh! If you have some nice results for a validation case (comparison with literature values) or for a tutorial, then your contribution is more than welcome, just let me (us) know.
geometry, ogive, stuck, su2, supersonic
Ahmed body simulation gives unexpected results in su2 6.0 anas651 SU2 0 March 28, 2018 04:42
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 03:40
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
