Ercan Umut
Rep Power: 4 ![]() |
Hello everybody,
I am trying to run a case with RANS-SST with farfield and symmetry BCs and freestream Mach number is 15. When I got the results it always shows that flow starts with mach 15 and slows down in the freestream as in the attached contour picture. What could be the reason for this? Last edited by CleverBoy; December 11, 2022 at 16:16. |
Pedro Gomes
Rep Power: 13 ![]() |
If you are running a 2.5D case, aka a slice (symmetry BCs on "front" and "back"), the slide needs to be on the y-z plane instead of x-y. That is, at 0 AoA and 0 side-slip the farfield velocity is in the z direction (instead of x for 2D mode).
#3 | |
Ercan Umut
Nevertheless, I run this same simulation with NEMO and there is no problem like this. |
Ercan Umut
Maybe this Mach contour will helpful. There are smaller Mach contour lines in the freestream. What could be the reason for this?
Pedro Gomes
This is the reason https://github.com/su2code/SU2/issues/1851
You can lower the inlet turbulence intensity to more realistic values for external aero problems like this: FREESTREAM_TURBULENCEINTENSITY= 5e-4 FREESTREAM_TURB2LAMVISCRATIO= 0.01 |
Ercan Umut
Perfect. Thank you for the research and solution for it. I will try it first time when I have free time.
Turbulent NACA 64-A010 stability response problem | kiloWatt | SU2 | 0 | December 1, 2020 13:26 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
Inlet Mach number problem | Imran358 | FLUENT | 0 | November 27, 2018 01:24 |
SU2 cfg file and runtime problems | hedley | SU2 | 19 | January 26, 2016 04:17 |
