Home > Forums > Software User Forums > SU2
Divergence Error
Like Tree2Likes
  • 2 Post By wallym
Old   September 19, 2022, 18:11
Default Divergence Error
Ercan Umut
CleverBoy is on a distinguished road
Hello everybody,
I am trying to simulate a re-entry case. When I start the analysis it diverge and stop the simulation at iteration 0 with following error:
Error in "void CSolver::SetResidual_RMS(const CGeometry*, const CConfig*)":
SU2 has diverged (NaN detected).
What is the reason of this?
CleverBoy is offline   Reply With Quote
Old   September 20, 2022, 04:13
bigfoot
bigfootedrockmidget is on a distinguished road
This can really be anything, from a bad mesh to a wrong setup or solver settings that are not strict enough.
The first thing to check is the mesh. Make sure that the mesh quality is good. Also, the combination of boundary conditions and the placement of inlets, outlets and far field is quite important. For instance, if the outlet is too close to your object of interest, there can be some unwanted interference that can also prevent convergence.
Which solver are you using? The regular compressible RANS or NS, or the NEMO solver?
Can you post a picture of your geometry+boundary conditions?
bigfootedrockmidget is offline   Reply With Quote
Old   September 20, 2022, 06:19
Ercan Umut
I am using RANS, SST V2003m and after that I will try it with NEMO. When I try to run it with SA it goes up to 70 iteration and gives the same error.
I am using GMSH and I am super new to almost everything about it. I import the geometry from SolidWorks.
As you said probably something's wrong with mesh or BCs. I will post the .cfg and .geo if you want.
I can try meshing and setting up the boundary conditions with Ansys Meshing tonight.
File Type: jpg WhatsApp Image 2022-09-20 at 11.16.31 AM.jpg (29.8 KB, 23 views)
Old   September 21, 2022, 12:18
Wally Maier
wallym is on a distinguished road
Nemo will not work with turbulence as of right now.
wallym is offline   Reply With Quote
Old   September 21, 2022, 18:04
Ercan Umut
Oh, that's sad to hear. I read the article "SU2-NEMO: An Open-Source Framework for High-Mach Nonequilibrium Multi-Species Flows" and there, it was written that NEMO has SA model within the framework. Does it not work properly? or was it removed?
Old   September 21, 2022, 18:30
Wally Maier
Rather, the NEMO code that exists in the develop branch does not have turbulence. The NEMO with turbulence branch just underwent large changes to allow for the use of the SST stage. The branch (feature_NEMO_turb) *should/may* work, but is undergoing additional testing before its put into the develop branch.
CleverBoy and Tomjugj like this.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
