Question about how to output the aerodynamic force distribution |
June 14, 2022, 06:05 |
Tomoki Yamazaki
Rep Power: 4 |
Hi, everyone.
Yesterday, I started the calculation about the wind turbine blade using SU2( ver7.3.1 blackbird ). I want to know how to output the aero force distribution on the rotor blade. I plan to use the force distribution for our in-house FEM structure calculation codes. I am looking into the information, but I can not find it. ( I only found how to output the sum of aerodynamic force and moment on a solid surface... ) If anyone knows about the aerodynamic force distribution output, would you mind telling me any information? I really appreciate any help you can provide. Tomoki |
June 14, 2022, 21:15 |
Pedro Gomes
Rep Power: 14 |
This is an example that extracts forces for all points on a surface: https://github.com/su2code/SU2/tree/...ating_NACA0012 |
June 16, 2022, 13:26 |
#3 | |
Tomoki Yamazaki
Rep Power: 4 |
Reading your sources, I understand how to get the distribution of aerodynamic forces. By the way, I copied your sources to my local environment to confirm the execution behavior and rebuilt SU2 with python wrappers and mpi options to run it. I succeeded in building SU2 with only python wrappers but failed building SU2 with python wrappers and mpi options. My local environment is set to python3.7.9 on virtualenv( installed mpi4py) and swig3.0.12 in CentOS7. If you have any ideas, would you mind telling me to solve this situation? This additional question is out of scope for the first question, so should I ask the same question in SU2 git issues...? The output errors in meson-log.txt are bellow: Code:
Message: Boost sources found. Program swig found: YES (/usr/bin/swig) Running command: /***/***/***/work/SU2/venv/bin/python3 -c import mpi4py; print(mpi4py.get_include()) --- stdout --- /***/***/***/work/SU2/venv/lib/python3.7/site-packages/mpi4py/include --- stderr --- Message: Using mpi4py from /***/***/***/work/SU2/venv/lib/python3.7/site-packages/mpi4py/include Pkg-config binary for 1 is cached. Determining dependency 'python-3.7m' with pkg-config executable '/usr/bin/pkg-config' env[PKG_CONFIG_LIBDIR]: /***/***/***/soft/Python-3.7.9/build/lib/pkgconfig env[PKG_CONFIG_PATH]: /opt/intel/compilers_and_libraries_2019.1.144/linux/mkl/bin/pkgconfig Called `/usr/bin/pkg-config --modversion python-3.7m` -> 0 3.7 env[PKG_CONFIG_LIBDIR]: /***/***/***/soft/Python-3.7.9/build/lib/pkgconfig env[PKG_CONFIG_PATH]: /opt/intel/compilers_and_libraries_2019.1.144/linux/mkl/bin/pkgconfig Called `/usr/bin/pkg-config --cflags python-3.7m` -> 0 -I/data/home/yamazaki/soft/Python-3.7.9/build/include/python3.7m env[PKG_CONFIG_LIBDIR]: /***/***/***/soft/Python-3.7.9/build/lib/pkgconfig env[PKG_CONFIG_ALLOW_SYSTEM_LIBS]: 1 env[PKG_CONFIG_PATH]: /opt/intel/compilers_and_libraries_2019.1.144/linux/mkl/bin/pkgconfig Called `/usr/bin/pkg-config --libs python-3.7m` -> 0 -L/***/***/***/soft/Python-3.7.9/build/lib -lpython3.7m env[PKG_CONFIG_LIBDIR]: /***/***/***/soft/Python-3.7.9/build/lib/pkgconfig env[PKG_CONFIG_PATH]: /opt/intel/compilers_and_libraries_2019.1.144/linux/mkl/bin/pkgconfig Called `/usr/bin/pkg-config --libs python-3.7m` -> 0 -L/***/***/***/soft/Python-3.7.9/build/lib -lpython3.7m WARNING: extract_all_objects called without setting recursive keyword argument. Meson currently defaults to non-recursive to maintain backward compatibility but the default will be changed in the future. SU2_PY/pySU2/meson.build:27:2: ERROR: Tried to form an absolute path to a source dir. You should not do that but use relative paths instead. To get include path to any directory relative to the current dir do incdir = include_directories(dirname) After this incdir will contain both the current source dir as well as the corresponding build dir. It can then be used in any subdirectory and Meson will take care of all the busywork to make paths work. Dirname can even be '.' to mark the current directory. Though you should remember that the current source and build directories are always put in the include directories by default so you only need to do include_directories('.') if you intend to use the result in a different subdirectory. |
June 16, 2022, 20:35 |
Pedro Gomes
Rep Power: 14 |
You can open a discussion on GitHub, maybe someone with a similar setup will know what to do.
June 16, 2022, 23:15 |
Tomoki Yamazaki
Rep Power: 4 |
I got it. I appreciate your kind response!!!
Output of force | Andrea-wwwwwwww | REEF3D | 2 | May 26, 2021 05:35 |
How to obtain radial force distribution graph from FLUENT? | mrswordf1sh | FLUENT | 2 | March 29, 2016 11:04 |
Aerodynamic Force, analytical calculation | punnag | Main CFD Forum | 0 | December 31, 2014 17:45 |
[OpenFOAM] spatial distribution of force coefficients in paraview&openfoam | kkpal | ParaView | 1 | April 21, 2013 08:15 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
