Home > Forums > Software User Forums > SU2
Finding Velocity and Pressure Gradients
Like Tree2Likes
  • 2 Post By bigfootedrockmidget
Old   April 25, 2022, 13:49
Default Finding Velocity and Pressure Gradients
pandamaster9 is on a distinguished road
Hello all,
I am fairly new to SU2 and CFD in general and I wanted to ask how to compute gradients for velocity and pressure respectively in SU2 Incompressible RANS.
Thank you.
pandamaster9 is offline   Reply With Quote
Old   April 26, 2022, 03:39
bigfoot
bigfootedrockmidget is on a distinguished road
Do you mean you would like to output and view the gradients? The gradients are not part of the output, so you have to compute them from velocity and pressure in e.g. paraview.
If you mean how we compute gradients for the discretization schemes, we do that with either Green-Gauss or weighted least squares:
% Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRAD= GREEN_GAUSS
% Numerical method for spatial gradients to be used for MUSCL reconstruction
% Options are (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES, LEAST_SQUARES). Default value is
% NONE and the method specified in NUM_METHOD_GRAD is used.
NUM_METHOD_GRAD_RECON = LEAST_SQUARES
PENGGEGE777 and pandamaster9 like this.
bigfootedrockmidget is offline   Reply With Quote
Old   April 26, 2022, 05:42
Thank you for the response. I have used a work around using finite difference from the solution files to find the gradients
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
