March 19, 2022, 06:22 |
Non-dimensional Mesh?
ibraheem alqadi
I was wondering if I need to nondimensionalize the mesh if I am running SU2 in nondimesional mode? Or does SU2 perform spatial nondimensionalization? |
March 20, 2022, 00:57 |
Rep Power: 6 |
Here is a manual for the non-dim issues:
https://su2code.github.io/docs_v7/Physical-Definition/ The ref. value of length is 1 which means you can just use one mesh for both dim and non-dim mode. |
February 1, 2024, 22:36 |
Dose the REYNOLDS_LENGTH in cfg file means the real length of 1 in the mesh file?
For example, the REYNOLDS_LENGTH=1m represents the 1 in the mesh file is 1meter? the REYNOLDS_LENGTH=0.001m represents the 1 in the mesh file is 0.001 meter? |
February 2, 2024, 09:11 |
bigfoot
Rep Power: 18 |
The Reynolds length L is used to compute the Reynolds number Re=rho * V * L / mu
So you choose it according to whatever is your characteristic length scale. The units of the mesh are meters (SYSTEM_MEASUREMENTS=SI) or inches (SYSTEM_MEASUREMENTS=US) If you want to change this, you have to scale your mesh in your mesher or with SU2_DEF |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] High quality mesh for wind in complex urban environment | ziboaa | OpenFOAM Meshing & Mesh Conversion | 1 | January 12, 2021 15:33 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
