January 25, 2022, 07:09 |
Printinf CFL at each iteration
Shahid Khan
Rep Power: 6 |
Is there any way I can print CFL value at each iteration on screen? I put AVG_CFL in SCREEN_OUTPUT but after some iterations its value becomes constant. I am not sure what does AVG_CFL actually giving? I saw it in one of the posts and tried it.
P.S.- I am new to SU2 Last edited by shahidkhan; January 25, 2022 at 09:15. |
January 26, 2022, 12:25 |
Wally Maier
Rep Power: 7 |
To check the options available for history/screen output, you can run SU2_CFD -d yourconfig.cfg. This should allow you peruse more options. Regarding CFL....The AVG_CFL is the average CFL of your entire problem. You can also print the minimum or maximum local CFL (MIN_ or MAX_CFL) numbers. If you are using an adaptative CFL, the local values of CFL will change noticeably which is why you may see some changes. Hope this helps. |
January 28, 2022, 02:04 |
#3 | |
Shahid Khan
Rep Power: 6 |
Thanks for your reply. It really helped. Also, can you please elaborate a bit more on MIN_ or MAX_CFL? like what they represent particularly what do we mean by locally term in that perspective? |
January 28, 2022, 09:20 |
bigfoot
Rep Power: 21 |
Slow calculation time on CFD server | killian153 | Hardware | 4 | July 27, 2021 08:28 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 15:05 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Hardware-Configuration for Fluent HPC-Pack (8x) | JohHaas | Hardware | 9 | March 3, 2015 14:25 |
Parallel runs slower with MTU=9000 than MTU=1500 | Javier Larrondo | FLUENT | 0 | October 28, 2007 23:30 |
