Home > Forums > Software User Forums > SU2
nonequilibrium testcase with 11 species
Like Tree2Likes
  • 1 Post By bigfootedrockmidget
  • 1 Post By wallym
Old   December 28, 2021, 05:03
Default nonequilibrium testcase with 11 species
anonymous
eli123 is on a distinguished road
I have completed the case viscwedge_mpp with the version SU2 NEMO 7.2.1 then i made changes to the cfg file to use the air_11 mutation model. After 8 iterations the code stops. I am attaching cfg file along with the screen dump, Any suggestions would be very helpful.
eli123 is offline   Reply With Quote
Old   December 28, 2021, 07:19
bigfoot
bigfootedrockmidget is on a distinguished road
Are you sure that this is the config file that you are using? In the SU2 output it says:
Maximum number of solver subiterations: 11.
and also:
Maximum number of iterations reached (ITER = 11) before convergence.
but your config file has:
% Number of total iterations
ITER= 1000
PENGGEGE777 likes this.
bigfootedrockmidget is offline   Reply With Quote
Old   December 28, 2021, 09:04
anonymous
Correct. I updated the number of iterations to get a more converged solution.
Old   December 29, 2021, 15:47
Wally Maier
wallym is on a distinguished road
Hi eli123,
My guess is that mesh being used is not high-enough quality for an 11-species gas, it is mainly there to run the regression cases. I would suggest refining the mesh, if possible.
Best,
Wally
wallym is offline   Reply With Quote
Old   January 6, 2022, 06:07
anonymous
Thank you for your prompt answer.
I tried to refine the mesh at an acceptable level, also decreased the CFL and finally ran to first order but the simulation failed again.
By the way is there any available tutorial using 11 species and Mutation++ ?
Old   January 6, 2022, 06:38
anonymous
...by decreasing the CFL to a value of 2e-3 the computation seems to continue
Old   January 7, 2022, 13:26
Wally Maier
That is an awfully low CFL number. Let me try this case on my end to see what may be happening. That behavior isn't right.
EDIT/UPDATE: I found an issue that may be causing the issue and a pull request is up on the github. Hopefully the issue will be resolved soon.
As for tutorials, the NEMO team is working on creating them in the next few months.
Old   January 9, 2022, 04:32
anonymous
thank you for the bug update.
The correction is relative to EULER IMPLICIT time scheme but as for now only EULER EXPLICIT time scheme is available with NEMO, right ?
Old   January 9, 2022, 13:51
Wally Maier
Both implicit and explicit are available in NEMO, at least in the develop branch of the code. As for the fix, there was an issue where the viscous Jacobians were being used even if the code was using the EXPLICIT formulation.
eli123 likes this.
Old   January 10, 2022, 03:45
anonymous
I used the develop version and got the following error message :
"Implicit time scheme is not yet implemented with Mutation++. Use EULER_EXPLICIT"
So, how can I run a simulation with 11 species ?
Any help will be appreciated.
Old   January 10, 2022, 12:45
Wally Maier
I apologize, I misspoke. The IMPLICIT solver is only available for SU2's native thermochemical library (SU2_NONEQ). Mutation++ is compatible yet.
Old   March 14, 2024, 03:17
anonymous
Hi Wally,
I downloaded the last version from the 'develop' branch and checked the viscwedge_mpp test case with 11 species.
I cannot converge and after 10 steps the simulation failed.
Can you please help me with this issue.
Regards,
Eli
Old   March 19, 2024, 09:10
Default non equilibrium viscwedge_mpp test case with 11 species
  #13
anonymous
It seems that a CFL of 1e-3 get rid of the convergence problem....
non equilibrium flow, real gases
Modelling Biomass Combustion via Species Transport Racheal FLUENT 39 January 8, 2022 08:42
UDF for Sorption in Species Transport through Porous Medium Kosch Fluent UDF and Scheme Programming 6 October 21, 2020 18:46
Combine Flux/Concentration BC in Electrochemical Species Model Anodos STAR-CCM+ 0 May 4, 2020 16:03
Site Species Diger FLUENT 6 May 3, 2016 06:36
Species order fluent Raddi FLUENT 1 March 13, 2009 01:21
