December 21, 2021, 07:35 |
Output coefficients of surfaces
Rep Power: 5 |
I have a problem where I need to extract aerodynamic coefficients on 2 different wall surfaces. I am running a dualtime rans simulation on SU2 7.2.1. I defined both walls in markers as noslip walls and in MARKER_MONITORING, but it seems that the history file still only contains the global coefficients. I managed to get the coefficients in the forces_breakdown.dat output, but it's rather inconvenient since I have to write all solutions quite frequently to be able to perform any kind of statistic analysis on the coefficients since it's a time accurate problem. Does anyone know of a way to extract a simple log file of the coefficients for each surface? Thank you |
December 22, 2021, 05:49 |
na
Rep Power: 8 |
Attach "_SURF" to the history output field will write the value for each individual surface in the marker list. So, for AERO_COEFF you would have to add"AERO_COEFF_SURF" to HISTORY_OUTPUT.
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 13:08 |
Time-accurate solution restart from steady state solution | jyotir | SU2 | 6 | December 8, 2021 09:34 |
How to control output time of pressureTools functions? | Fluido | OpenFOAM Post-Processing | 1 | May 19, 2014 09:49 |
RNG diverged during the analysis the flow over a multi element airfoil, why? | s.m | OpenFOAM Running, Solving & CFD | 0 | August 5, 2013 09:39 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 13:30 |
