Home > Forums > Software User Forums > SU2
NICFD in SU2
Like Tree3Likes
  • 1 Post By Nicola_Fontana
  • 2 Post By TKatt
Old   November 2, 2021, 06:42
Default NICFD in SU2
Nicola Fontana
Nicola_Fontana is on a distinguished road
Hi, I'm a newbie in CFD. I'm triyng to model a flux of supercritical CO2, and for this application I can't use Peng-Robinson EoS, because it is rather ineffective near the critical point. For a faster and better solution I read in different forum that it is possible to combine SU2 with a look up table, with the " feature_adjoint_lut ". Here the mention of the feature in the github forum:
https://github.com/su2code/SU2/issues/794
There are some reference about this topic also in some paper, as the following:
https://su2code.github.io/documents/...821_012013.pdf
Unfortunately, seems that this option is implement only in the 5.0.0 version:
https://github.com/su2code/SU2/tree/feature_adjoint_lut
In any case, I can't find an example in which this feature is used, and I can figure out how to use SU2 with a look up table.
Someone can please help?
Thank you in advance,
Nicola
PENGGEGE777 likes this.
Nicola_Fontana is offline   Reply With Quote
Old   November 3, 2021, 12:19
na
TKatt is on a distinguished road
I am sure feature_adjoint_lut never made it to develop ... which you seem to already have checked.
Work on SU2 + look up table is currently done in feature_flamelet which is also in PR1223 on github. This is working in the scope of that PR and should in theory be what you are looking for but I personally cant give support on that.
So unfortunately there is no current plug and play solution in develop or master. And for the sake of your own time I would keep my hands of feature-branches unless you are interested in putting in some coding and debugging work yourself ... in that case you are more than welcome.
Best, Tobi
TKatt is offline   Reply With Quote
feature_adjoint_lut, lookup table, nicfd, su2
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 19:28
SU2 Incompressible tutorials not working kp137 SU2 8 July 16, 2019 21:48
Introducing SU2 International Developers Society (IDS) fpalacios SU2 News & Announcements 1 June 17, 2019 23:38
Official release of SU2 V3.0 and SU2 Educational V1.0 fpalacios SU2 News & Announcements 2 January 22, 2014 06:28
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
