Home > Forums > Software User Forums > SU2
Cp and x/c for Turbulent NACA 0012
Like Tree1Likes
  • 1 Post By bigfootedrockmidget
Old   October 27, 2021, 07:43
Default Cp and x/c for Turbulent NACA 0012
robert landis
koala123 is on a distinguished road
Hi everyone,
I am trying to replicate the results seen here
https://su2code.github.io/tutorials/...lent_NACA0012/
I have SU2 version 7.0.2. Installed, ran fine. I was able to view the pressure map on Paraview.
How do I get the Cp vs x/c plot though? I read the output format here
https://su2code.github.io/docs_v7/Custom-Output/
to say
OUTPUT_FILES= (RESTART, TECPLOT_ASCII, SURFACE_TECPLOT_ASCII)
Then reran the simulation, and now I have surface_flow.dat, and flow.dat, I can read the Pressure_Coefficient from this file, but what is it plotted against?
Thanks,
koala123 is offline   Reply With Quote
Old   October 28, 2021, 14:21
bigfoot
bigfootedrockmidget is on a distinguished road
I always use PARAVIEW_MULTIBLOCK, which gives the boundaries as separate entities. You can then do an Extract Block to select only the naca profile wall boundary. You can then select the Plot Data filter to visualize only the data on the surface as a function of x-coordinate.
koala123 likes this.
bigfootedrockmidget is offline   Reply With Quote
tutorials
